cjlong45 17 Posted May 24, 2023 Posted May 24, 2023 Hi I recently installed podsync and have up and running however when I add the url the post cast plugin only shows a folder with a picture on it and once inside the folder it has zero items which is not the case on the podsync server please help me
cjlong45 17 Posted May 24, 2023 Author Posted May 24, 2023 Its odd it's doing the same thing on other pod cast apps showing info but not the videos or mp3s
Luke 42255 Posted May 24, 2023 Posted May 24, 2023 12 minutes ago, cjlong45 said: Does emby post casts support media rss Hi, yes the Emby podcast plugin does support rss feeds.
cjlong45 17 Posted May 24, 2023 Author Posted May 24, 2023 1 hour ago, Luke said: Hi, yes the Emby podcast plugin does support rss feeds. If I pm you the url do you think you could possibly tell me what's going wrong please
Luke 42255 Posted May 25, 2023 Posted May 25, 2023 Try running the refresh internet channels scheduled task, and then please attach the emby server log: How to Report a Problem Thanks.
cjlong45 17 Posted May 25, 2023 Author Posted May 25, 2023 Just now, cjlong45 said: embyserver.txt 31.88 MB · 0 downloads 9 hours ago, Luke said: Try running the refresh internet channels scheduled task, and then please attach the emby server log: How to Report a Problem Thanks. refreshing internet channels now allows me to see the feeds and details on them but when i try to play any it doesnt work
cjlong45 17 Posted May 25, 2023 Author Posted May 25, 2023 6 minutes ago, cjlong45 said: embyserver.txt 31.88 MB · 0 downloads this one instead embyserver.txt
Luke 42255 Posted May 25, 2023 Posted May 25, 2023 Did you configure this as your podcast url? http://www.itunes.com/dtds/podcast-1.0.dtd That does not appear to point to an rss feed.
