DJX 18 Posted May 19, 2023 Posted May 19, 2023 (edited) 23 hours ago, Luke said: So you’re saying that with normal usage of the device, that the auto orientation doesn’t always work properly? Something has just broken in the latest android on the same topic. Videos taking in a portrait manner dont play back that way, but instead is rotated landscape. Example attached. Edit: seems to work when direct streaming only. When i change the quality so it has to transcode, it doesnt respect the orientation now Edited May 19, 2023 by DJX
Luke 42241 Posted May 20, 2023 Posted May 20, 2023 @DJX Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
DJX 18 Posted May 21, 2023 Author Posted May 21, 2023 https://emby.media/community/index.php?/topic/106851-phone-video-aspect-ratio
DJX 18 Posted May 21, 2023 Author Posted May 21, 2023 I previously reported it. Was addressed. Now broken in latest android emby client
Luke 42241 Posted May 21, 2023 Posted May 21, 2023 Can you please attach the information requested so that we can look at an example? Thanks .
DJX 18 Posted May 22, 2023 Author Posted May 22, 2023 Video Title4K H264 CodecH264 Codec Tagavc1 ProfileHigh Level51 Resolution3840x2160 Aspect Ratio16:9 InterlacedNo Framerate29.835 Bitrate48 mbps Colour Primariesbt709 Colour Spacebt709 Colour Transferbt709 Bit Depth8 bit Pixel Formatyuv420p Reference Frames1 Rotation-90 Audio TitleEnglish AAC stereo (Default) LanguageEnglish CodecAAC Codec Tagmp4a ProfileLC Layoutstereo Channels2 ch Bitrate256 kbps Sample Rate48,000 Hz DefaultYes @Luke embyserver.txt ffmpeg-transcode-d7dfb8c0-e50b-497d-aa44-da1a491985de_1.txt
Luke 42241 Posted September 6, 2025 Posted September 6, 2025 Updating this topic as well: Emby Server beta 4.9.1.26 which has just been released, has a fix for portrait videos orientation when transcoding
