tedfroop 34 Posted May 17, 2023 Posted May 17, 2023 This likely has to do with some changes at thetvdb but when you change the sort order of the episodes (IE: Season, Aired, DVD) is there a change in where Emby looks for artwork? I just noticed that Futurama, which has 7 seasons, has 8 dvd's, and Emby is looking at Seasons instead of DVD's for the artwork, so it had to be manually pointed to season 8 dvd location to find the cover art. I believe this is a change at thetvdb as they used to have a "pool" of artwork for Seasons, DVD's, and Aired.
Luke 42185 Posted May 17, 2023 Posted May 17, 2023 Hi, actually it does look like our tvdb season image provider is hardcoded for aired order so we'll have to take a look at that. Thanks. 1
tedfroop 34 Posted May 17, 2023 Author Posted May 17, 2023 Awesome, thanks very much. It's a recent change on their end - and a good one for matching accuracy. Took me a bit to figure out what was going on. 1
