jlficken 3 Posted July 8, 2023 Author Posted July 8, 2023 (edited) 110Mbps is fine on the Roku. I found versions of this video up to 400Mbps as well…nice! Edited July 8, 2023 by jlficken
jlficken 3 Posted July 8, 2023 Author Posted July 8, 2023 Here’s some tests with really high bitrates on the A90J and WiFi.
speechles 2062 Posted July 9, 2023 Posted July 9, 2023 Hi. It is possible to do this and get higher than 110Mb/sec on your Roku. Just disable the ability to transcode the video stream for that user in Emby server user settings. Then it will have no choice but to attempt to send these large bitrate video to the Roku. You can see if it is pleasurable to watch this way or if it just causes endless buffering Hell. please let us know what you discover on your model of Roku. But be forewarned, this is why we do not go that large in the bitrate quality on the Roku.
jlficken 3 Posted July 9, 2023 Author Posted July 9, 2023 I can’t get any of my test videos so far to play but I’ll keep looking for something to test with. I guess I’ll just have to use the A90J for high bitrate content even though I don’t foresee the Roku having issues with even 160Mbps from what I’ve seen in testing so far. Turning off all transcoding ability for a user just isn’t a good solution.
ebr 16334 Posted July 9, 2023 Posted July 9, 2023 12 hours ago, jlficken said: Turning off all transcoding ability for a user just isn’t a good solution Hi. He wasn't offering it as a solution. He was suggesting to do that temporarily to allow you to test if the items will play smoothly.
ebr 16334 Posted July 9, 2023 Posted July 9, 2023 Here's my test of the 160Mb Jellyfish sample on a Roku Premiere 4K
jlficken 3 Posted July 9, 2023 Author Posted July 9, 2023 Okay I got it to play on the Roku Up to 200Mbps on WiFi the entire clip plays with no issues and about a 3 second load time after hitting play. When trying the 250Mbps clips it starts after about 3 seconds, however, it does drop a frame every so often. 300Mbps and 400Mbps test files don’t work as it’ll play for a couple of seconds and then reload and play for a few more seconds repeatedly. I never got the buffering message mentioned above though. Were you on WiFi or wireless? To me when on WiFi it appears that the Roku Ultra is fine up to 200Mbps. 1
