chempionmaks 1 Posted November 14, 2023 Author Posted November 14, 2023 About port mapping's, I turned off it, for now. Thank you. I will update to 4.8 later
Luke 42244 Posted November 15, 2023 Posted November 15, 2023 Do you use more than one subnet? have you customized any server network settings?
chempionmaks 1 Posted November 15, 2023 Author Posted November 15, 2023 Yes, I have two networks. I try change network setting, because I want check all options before disturbing people :)) but it's no helps I set "LAN networks" to "192.168.11.0/24, 192.168.0.0/24", but it's be empty before and it's be same situation, from "Play On" I see only Dynaudio.
Luke 42244 Posted November 16, 2023 Posted November 16, 2023 Do you need to customize those two options? It's the second one that might be causing the problem.
chempionmaks 1 Posted November 16, 2023 Author Posted November 16, 2023 I'm sure everything is fine with the network setup. Networking is my job :)) I removed emby via dpkg -r and installed it again. Now it works. With the same network settings. I suspect something went wrong with the update. Somehow I didn't think to delete and install again. I apologize for wasting your time.
Luke 42244 Posted December 27, 2023 Posted December 27, 2023 @chempionmakscan you please test again with the Emby Dlna 1.3.0+ plugin update and let us know if it is still behaving the same way? Thanks !
chempionmaks 1 Posted December 29, 2023 Author Posted December 29, 2023 @LukeI'm update my server few weeks ago, now Emby Version 4.7.14.0 DLNA 1.3.0.0 And it's works great. I don't have any issues with my speakers by DLNA. If you need some logs, I can prepare(now debug is off) it and post here, but not today
chempionmaks 1 Posted January 3, 2024 Author Posted January 3, 2024 Hi @Luke Today I faced problem: strange behavior of the web interface, some strange blinking. And I can't open "remote control" of DLNA, it's closed in same time But music play well, without problems, not interupted. Speakers discovery working well to. I tried other browsers, the situation is the same. I recorded a short video and added it to the attached archive. There are also lot of errors in the logs: *** Error Report *** Version: 4.7.14.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Linux version 5.10.0-23-amd64 (debian-kernel@lists.debian.org) (gcc-10 (Debian 10.2.1-6) 10.2.1 20210110, GNU ld (GNU Binutils for Debian) 2.35.2) #1 Framework: .NET 6.0.20 OS/Process: x64/x64 Runtime: opt/emby-server/system/System.Private.CoreLib.dll Processor count: 4 Data path: /var/lib/emby Application path: /opt/emby-server/system System.Xml.XmlException: System.Xml.XmlException: An error occurred while parsing EntityName. Line 1, position 705. at System.Xml.XmlTextReaderImpl.Throw(Exception e) at System.Xml.XmlTextReaderImpl.HandleEntityReferenceAsync(Boolean isInAttributeValue, EntityExpandType expandType) at System.Xml.XmlTextReaderImpl.ParseTextAsync_ParseEntity(Int32 outOrChars, Char[] chars, Int32 pos, Int32 rcount, Int32 rpos, Int32 orChars, Char c) at System.Xml.XmlTextReaderImpl.ParseTextAsync_AsyncFunc(Task`1 task) at System.Xml.XmlTextReaderImpl._ParseTextAsync(Task`1 parseTask) at System.Xml.AsyncHelper.ContinueBoolTaskFuncWhenFalseCoreAsync[TArg](Task`1 task, Func`2 func, TArg arg) at System.Xml.XmlTextReaderImpl.SkipAsync() at System.Xml.XmlSubtreeReader.SkipAsync() at Emby.Dlna.PlayTo.Device.ParseTrackMetadata(XmlReader reader, uBaseObject result) at Emby.Dlna.PlayTo.Device.ParseTrackMetadata(XmlReader reader, uBaseObject result) at Emby.Dlna.PlayTo.Device.ParseTrackMetadata(String trackMetadata, Boolean debugLog) at Emby.Dlna.PlayTo.Device.GetTrackObject(String trackUri, String trackMetadata, Boolean allowNullTrackMetadata) Source: System.Private.Xml TargetSite: Void Throw(System.Exception) I enabled debug and restarted the server. The last log file should contain complete information emby-logs.tar.gz
Luke 42244 Posted May 13, 2024 Posted May 13, 2024 @chempionmaksplease try the 1.4.0 update to the Emby Dlna plugin and let us know if this resolves your issue. Thanks !
