chempionmaks 1 Posted May 15, 2023 Posted May 15, 2023 Hello. I have PC with linux Debian 11 (bullseye) with installed emby-server 4.7.11.0 and av-reciever yamaha RX-V685. I listen music from Emby on yamaha by DLNA, and it' s work great before today Today my reciever didn't find Emby-server I found errors in logs 2023-05-15 19:09:52.867 Error DLNA: Error updating device info for Кімната для прослуховування *** Error Report *** Version: 4.7.11.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restarte xitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Linux version 5.10.0-23-amd64 (debian-kernel@lists.debian.org) (gcc-10 (Debian 10.2.1-6) 10.2.1 20210110, GNU ld (GNU Binutils for Debian) 2.35.2) #1 Framework: .NET 6.0.8 OS/Process: x64/x64 Runtime: opt/emby-server/system/System.Private.CoreLib.dll Processor count: 4 Data path: /var/lib/emby Application path: /opt/emby-server/system System.Xml.XmlException: System.Xml.XmlException: '=' is an unexpected token. The expected token is ';'. Line 1, position 2302. at System.Xml.XmlTextReaderImpl.Throw(Exception e) at System.Xml.XmlTextReaderImpl.Throw(String res, String[] args) at System.Xml.XmlTextReaderImpl.ThrowUnexpectedToken(String expectedToken1, String expectedToken2) at System.Xml.XmlTextReaderImpl.ThrowUnexpectedToken(Int32 pos, String expectedToken1, String expectedToken2) at System.Xml.XmlTextReaderImpl.HandleEntityReference(Boolean isInAttributeValue, EntityExpandType expandType, Int32& charRefEndPos) at System.Xml.XmlTextReaderImpl.ParseText(Int32& startPos, Int32& endPos, Int32& outOrChars) at System.Xml.XmlTextReaderImpl.FinishPartialValue() at System.Xml.XmlTextReaderImpl.get_Value() at System.Xml.Linq.XContainer.ContentReader.ReadContentFrom(XContainer rootContainer, XmlReader r) at System.Xml.Linq.XContainer.ReadContentFrom(XmlReader r) at System.Xml.Linq.XDocument.Load(XmlReader reader, LoadOptions options) at System.Xml.Linq.XDocument.Parse(String text, LoadOptions options) at Emby.Dlna.PlayTo.SsdpHttpClient.SendCommandAsync(String url, DeviceService service, String command, ReadOnlyMemory`1 postData, CancellationToken cancellationToken, Boolean logRequest, String header ) at Emby.Dlna.PlayTo.Device.GetPositionInfo(TransportCommands avCommands, CancellationToken cancellationToken) at Emby.Dlna.PlayTo.Device.TimerCallback(Object sender) Source: System.Private.Xml TargetSite: Void Throw(System.Exception) So I'm turning on debug for DLNA. Full logs in attach Sorry if I wrote something wrong, I'm newbie here emby-logs.tar
Luke 42244 Posted May 15, 2023 Posted May 15, 2023 Hi, can you enable debug logging in both dlna settings and in emby server log settings, then repeat the test and provide a new log? Make sure to turn off those debug options afterwards. Thanks.
chempionmaks 1 Posted May 22, 2023 Author Posted May 22, 2023 Hello Luke. Thanks for the reply and sorry for the delay in my reply. I hope I did everything right emby-logs.tar
Luke 42244 Posted May 23, 2023 Posted May 23, 2023 Hi, can you try this test version of the dlna plugin? Emby.Dlna.zip Just unzip it to /var/lib/emby/plugins, then restart the server. Whether this succeeds or not, please attach the emby server log again. Thanks !
chempionmaks 1 Posted May 23, 2023 Author Posted May 23, 2023 unfortunately it didn't help :( emby-logs.tar 1
Luke 42244 Posted May 24, 2023 Posted May 24, 2023 OK, one more try: Emby.Dlna.zip And again no matter what happens, please attach the emby server log. thanks !
chempionmaks 1 Posted May 25, 2023 Author Posted May 25, 2023 Hello, @Luke. I'm try it tomorrow and give you feedback. Sorry for delay
chempionmaks 1 Posted May 26, 2023 Author Posted May 26, 2023 I have checked, and now it's working fine. Thank you. However, I also tried the "Play To" feature, and it's behaving strangely: When a song ends, the next one doesn't start. I'm not sure if it used to work before; I just tried it now. It's not very important to me, but thank you for what you have already done. emby-logs.tar
Luke 42244 Posted May 26, 2023 Posted May 26, 2023 @chempionmaksThanks ! Can you please try this version now? Emby.Dlna.zip And again, please attach the emby server log regardless of the outcome. Thanks !
chempionmaks 1 Posted May 27, 2023 Author Posted May 27, 2023 Now it's not working, musicCast din't find Emby and I din't see DLNA plugin in settings emby-logs.tar
Luke 42244 Posted May 28, 2023 Posted May 28, 2023 @chempionmakssorry, my mistake. I gave you a version that is only compatible with the 4.8 beta server. Here is the correct version: Emby.Dlna.zip Please try it, let me know the result, and attach the emby server log. Thanks !
chempionmaks 1 Posted May 29, 2023 Author Posted May 29, 2023 Same problem, next song doesn't start emby-logs.tar
Luke 42244 Posted May 30, 2023 Posted May 30, 2023 7 hours ago, chempionmaks said: Same :( emby-logs.tar 75.54 MB · 0 downloads What exactly happened? This log looks error free to me.
chempionmaks 1 Posted May 30, 2023 Author Posted May 30, 2023 yes, it's true, I didn't find errors in log. But when one song from the queue finishes, the next one doesn't start. Between when I start play music from musicCast it's working fine
Solution Luke 42244 Posted May 30, 2023 Solution Posted May 30, 2023 OK please try this version: Emby.Dlna.zip Thanks.
chempionmaks 1 Posted May 31, 2023 Author Posted May 31, 2023 Thank you so much, Luke. Now it's working great. From browser playback not stop when song ends. And musiccast app "sees" DLNA-server. I'm happy now emby-logs.tar
chempionmaks 1 Posted May 31, 2023 Author Posted May 31, 2023 I also tested it on Devialet Phantom 1, and it works well too. But on DynAudion Music 7 the queue stops when a song ends. emby-logs.tar
chempionmaks 1 Posted November 13, 2023 Author Posted November 13, 2023 Hello Emby Team. Today I'm install last update(Version 4.7.14.0) on my server(Debian 11 bullseye). unfortunately, have encountered the DLNA issue that we previously discussed. Now I see only Dynaudio, but can't see Devialet and Yamaha emby-logs.tar
Luke 42244 Posted November 14, 2023 Posted November 14, 2023 Are you sure these devices are powered on? The server logs contain no mention of them. I do see some crashes in your log files coming from the port mapper plugin, which I've never seen before. I'll push out an update to the plugin to resolve that, although the fix will be targeting the 4.8 beta server. So to stop that crashing, you can either update to the 4.8 beta server or disable the server's automatic port mapper in server network settings.
chempionmaks 1 Posted November 14, 2023 Author Posted November 14, 2023 Of course, I’m sure that the device is turned on :)) In particular, I used MusicCast from Yamaha to listen to music from DLNA-server and it works. But I did this after I sent you the logs, I can archive it again and send it to you. Olso other devices on the network “see” the speaker systems emby-logs.tar
