Synology DS918+ Emby 3 Posted May 14, 2023 Posted May 14, 2023 Home screen "default screen" setting does not change in Emby Android Nvidia shield Tv I have emby server (Version 4.7.11.0) in synology Nas, When I change the Home screen "default screen" settings, example to folders, it does not change in the android app in nvidia shield tv,
Solution GrimReaper 4896 Posted May 14, 2023 Solution Posted May 14, 2023 AndroidTV app has its own default/landing page settings, it does not inherit - enter any library, select Library settings (cog icon top right), set Default tab.
Luke 42242 Posted May 14, 2023 Posted May 14, 2023 Hi. Can you try sideloading our standard android app on the same device and see how that compares? https://emby.media/emby-for-android.html Thanks.
Synology DS918+ Emby 3 Posted May 15, 2023 Author Posted May 15, 2023 20 hours ago, GrimReaper said: AndroidTV app has its own default/landing page settings, it does not inherit - enter any library, select Library settings (cog icon top right), set Default tab. Yes it works, Thank you 1
