KodiaK 3 Posted May 13, 2023 Posted May 13, 2023 Hello, I have an issue I've never had before. When playing a video file which is using DTS sound encoding I have no sound in the Android App. If I play the same file on the PC (through Emby) the sound is there. I was under the impression that emby supports DTS audio. Am I wrong or is there something wrong in my config? This is what I see in emby dashboard
ebr 16337 Posted May 13, 2023 Posted May 13, 2023 Hi. We support anything the outbound equipment does. Are you sure it is all DTS? Do other items have the same issue? There should be a setting in the app playback settings of whether or not to pass DTS on.
KodiaK 3 Posted May 13, 2023 Author Posted May 13, 2023 The TV supports DTS, the sound bar connected to the TV (Sony HT-RT4) also supports DTS. What do you mean by "app playback settings"?. I looked in the emby app settings, but could not find any setting related to DTS.
ebr 16337 Posted May 14, 2023 Posted May 14, 2023 15 hours ago, KodiaK said: The TV supports DTS, the sound bar connected to the TV (Sony HT-RT4) also supports DTS If that is the case, then under the settings in the app - Playback Settings, there will be an option for DTS and DTS-HD. If those options are not there, it means your system is not reporting support for DTS. Can you please play an item with a DTS track for a few seconds and then follow the instructions to send a log from the app?
KodiaK 3 Posted May 14, 2023 Author Posted May 14, 2023 I found the settings you mentioned. If I uncheck DTS passthrough and DTS-HD passthrough I get back the sound. However in the dashboard it still says direct play (no sound transcoding).
ebr 16337 Posted May 14, 2023 Posted May 14, 2023 7 hours ago, KodiaK said: I found the settings you mentioned. If I uncheck DTS passthrough and DTS-HD passthrough I get back the sound. However in the dashboard it still says direct play (no sound transcoding). Correct - the app is decoding it internally.
