Meeko 35 Posted May 10, 2023 Posted May 10, 2023 Guten Morgen, habe das Problem das bei nur einem Sender (Pro7) das Bild ruckelt, das ist aber nur am Iphone 11!? firetv, pc und iphone 6 gibt es keine Probleme. bin mit meinem Latein am ende, hat jemand das gleiche Problem? LG RPReplay_Final1683697865.mov
Luke 42240 Posted May 10, 2023 Posted May 10, 2023 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
Meeko 35 Posted May 10, 2023 Author Posted May 10, 2023 (edited) 1 hour ago, Luke said: Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks! The attached Video is an example. The issue is only on Iphone 11!! On other Iphones and ipad no stutter Edited May 10, 2023 by Soldize
Meeko 35 Posted May 10, 2023 Author Posted May 10, 2023 1 hour ago, Luke said: Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks! Here my Server LOG embyserver.txt
Solution Luke 42240 Posted June 5, 2023 Solution Posted June 5, 2023 @Soldizecan you please try again with the latest update to Emby for iOS? Thanks ! 1
Meeko 35 Posted June 5, 2023 Author Posted June 5, 2023 1 hour ago, Luke said: @Soldizecan you please try again with the latest update to Emby for iOS? Thanks ! Oh yes its fixed! Big thanks! best regards 1
