tux1980 1 Posted May 10, 2023 Posted May 10, 2023 Hi dear Kodi Community, I'm running on Kodi 20.1 with Emby Server 4.7.11.0 since my last update to Emby Server Version 4.7.11.0 and next-gen-emby kodi client V 8.1.1 my customized Video settings are not stored anymore. That's gruesome for me since I do changes on every single movie I watch. I tried it with the "default mode" and "native path mode" - same result, the settings won't there anymore after Kodi has been restarted. With the previous Version, when continue the movie the settings would still be in effect. I mean things like subtitles settings or zoom amount. To emphasize what I mean, attached two screenshots. After restarting Kodi, die "Zoom Amount" is back to 1.00 again and the Subtitles offset as well. Any hint or Idea? Thanks tux1980
quickmic 1709 Posted May 10, 2023 Posted May 10, 2023 (edited) I'll check it, but might be a Kodi issue. It's a plugin issue, I'll fix it in next version Edited May 10, 2023 by quickmic
tux1980 1 Posted May 11, 2023 Author Posted May 11, 2023 Hi. That's what I noticed too since when connecting with my media sources directly via NFS/SMB without using the Emby Next-Gen client there are no issues at all, this only happens with the emby client/server. Thanks for checking this out. You know by accident when the next z-release is going to happen with the bugfix being integrated? br
tux1980 1 Posted May 20, 2023 Author Posted May 20, 2023 Hi. Obviously with Version 8.1.4 it is working again and the settings are being memorized again even after restarting Kodi br 1
