Meeko 35 Posted May 8, 2023 Posted May 8, 2023 Hi, Could you add more options for conversion. Unfortunately I have the following problem when converting to hevc: When I set a costum bitrate then ffmpeg converts the video from 1080p to 720p! If I select original quality then the resolution remains untouched. Problem is that the quality is not good. The best would be if you do not change the resolution at costum bitrate or make an extra option for it. best regards. Translated with www.DeepL.com/Translator (free version)
ebr 16338 Posted May 8, 2023 Posted May 8, 2023 Hi, there's already an open request for this or something functionally equivalent. Please join in and contribute to the existing discussion at: 1
