eraser8 55 Posted October 24, 2014 Posted October 24, 2014 (edited) Hi Redshirt, first of all, your lastests updates are really nice improved. Congratulation and continu your good job. I have a question. Is it normal I can control other device that are logged with the same login? For example, I have 2 users available for login. HTPC and ADMIN. My htpc computer is logged with "HTPC" user and me, I'm logged with "ADMIN" user on my tablet. But for now, I cannot remote control my HTPC??? I need to loggin with "HTPC" user on my tablet to be able to control it. Can this be configurable? I would like very much to don't switch between user to be able to control different device. Thanks Edited October 24, 2014 by eraser8
Redshirt 1487 Posted October 24, 2014 Posted October 24, 2014 Hi, The client is now honoring the server setting. If you navigate into the account settings on the server dashboard. For each user there's an option to "Allow remote control of other users". 1
eraser8 55 Posted October 24, 2014 Author Posted October 24, 2014 Hi, The client is now honoring the server setting. If you navigate into the account settings on the server dashboard. For each user there's an option to "Allow remote control of other users". Hi Redshirt, thanks for the fast response. I already check these setting and both are checked. Before your big recent release (I think is from 2 weeks) if I remember wel, it worked. Moreover, when I go to server dashboard with different login, it works anyway.... Only on Android it doesn't works. Thanks again
Redshirt 1487 Posted October 24, 2014 Posted October 24, 2014 I'm not able to reproduce with my current dev builds. We'll have to see if it's still an issue after the next update. 1
eraser8 55 Posted October 24, 2014 Author Posted October 24, 2014 Thanks a lot Redshirt for your test. I can try to reinstall my server... Thanks again
Redshirt 1487 Posted October 24, 2014 Posted October 24, 2014 Leaving unanswered for now. I mean the dev builds of the Android client. Shouldn't be more than a few days before it's public.
eraser8 55 Posted October 24, 2014 Author Posted October 24, 2014 Ok fine, I retest it by deinstall/reinstall server and android app but it doesn't works anymore. I can only remote control the device that are logged with the same user than I logged on my android tablet. Server Version 3.0.5395.0 MB Classic Version 3.0.224.0 Android: 2.0.87 Thanks to keep it open
eraser8 55 Posted October 25, 2014 Author Posted October 25, 2014 (edited) Hi Redshirt, Just to let you know that I've test the problem on my Brother's HPTC setup and it does the same problem. So, I believe there is a problem somewhere to return the list of device available for remote. BUT, there is only the Android that have the problem. It works well from the web browser. Thanks Edited October 25, 2014 by eraser8
