ebr 16334 Posted October 30, 2014 Posted October 30, 2014 Only thing else I can think of is to uninstall both MBS and MBC and do clean installs? I don't believe that will have an effect. The server isn't involved in this at all and all MBC is doing is telling WMC to play the item. I'm stumped.
Wilky13 21 Posted October 31, 2014 Author Posted October 31, 2014 Me too. Wtv files in 'Recorded TV' play fine also. So I don't think it is WMC.
Luke 42241 Posted October 31, 2014 Posted October 31, 2014 Okay, I will use the "play to" function of WMP to sling it to the Xbox and also open it using the Xbox Video app directly. Was this ever tried?
Wilky13 21 Posted November 4, 2014 Author Posted November 4, 2014 (edited) Yes. I also got the new network switch and the network tuner in WMC (on the extender) is maxed out with a good signal. When accessing the movie from the Xbox Video App the movie plays with clear video, no stutters. When using the 'Play To' function on the HTPC to push the movie to the Xbox, it again plays clearly, however it would pause a split second every 10 seconds or so (buffering?). When I access the movie through the MB3 app inside WMC on the Xbox extender the video quality is still very poor (blocky). No stuttering or buffering, though. Also, how come MBS does't show up under available servers in the Xbox Video App? Only 'HTPC-i3: HTPC-i3' and 'Plex Media Server: HTPC-i3' show up. DLNA is turned on. Edited November 4, 2014 by Wilky13
ebr 16334 Posted November 4, 2014 Posted November 4, 2014 Are you using the custom player interface? Any zoom setting? Have you done anything with the over/under scan settings? What happens if you turn off the custom interface? 1
Luke 42241 Posted November 4, 2014 Posted November 4, 2014 Yes. I also got the new network switch and the network tuner in WMC (on the extender) is maxed out with a good signal. When accessing the movie from the Xbox Video App the movie plays with clear video, no stutters. When using the 'Play To' function on the HTPC to push the movie to the Xbox, it again plays clearly, however it would pause a split second every 10 seconds or so (buffering?). When I access the movie through the MB3 app inside WMC on the Xbox extender the video quality is still very poor (blocky). No stuttering or buffering, though. Also, how come MBS does't show up under available servers in the Xbox Video App? Only 'HTPC-i3: HTPC-i3' and 'Plex Media Server: HTPC-i3' show up. DLNA is turned on. Ok, but please go back and test exactly how I asked. Do not use the Xbox Video app. Set it up with the WMC video library and try to play with WMC on the extender. Comparing it to the Xbox app is not a fair comparison because the Xbox app has seen more updates over the years. I anticipate you will see the same thing with the WMC video library which will be an indication that it is not Media Browser-related. I'm sure there are plenty of people here who can help you set it up.
Wilky13 21 Posted November 4, 2014 Author Posted November 4, 2014 I opened the file using the 'Movies' section of WMC on the extender. The quality was poor like with MBC. Does this help?
ebr 16334 Posted November 4, 2014 Posted November 4, 2014 I opened the file using the 'Movies' section of WMC on the extender. The quality was poor like with MBC. Does this help? Yep. That means it has nothing to do with MB. For some reason, the extender playback is being dumbed down by WMC or the xbox itself. I'm not sure what to tell you to try but there must be some sort of configuration or something to solve this. I'll call in our resident 360 super-user and see if he has any ideas... @@BAS?
Wilky13 21 Posted November 4, 2014 Author Posted November 4, 2014 Okay, thanks. I'll also start a thread at TGB to see if anyone has an idea.
BAS 225 Posted November 5, 2014 Posted November 5, 2014 (edited) I'm running Windows 7 X64 fresh install, LAV Filters and this problem is noticeable for me as well. All I can say is no registry tweaking, no codec tweaking has been able to get these to look as good as they do on the pc. WMC always transcodes these files, the problem is their transcoding is just horrid. A few things to check to at least help the situation. 1. Make sure you have run the Windows Experience Index. 2. Check your network adapter settings on the hosting computer, make sure Flow Control is Enabled. 3. Also in the network adapter settings area it is recommend by Microsoft to change your Speed & Duplex setting from Auto Negotiation to 100 Mbps Full Duplex as the 360 only supports 100 Mbps traffic. I leave mine on Auto Negotiation as i have to many other things coming through this network port to limit it but you should notice a change in video performance as well as scrolling performance on the 360. I know its not top priority and the fact that there is going to be a official 360 and Xbox One apps from the Media Browser team it becomes even more invalid but I will state that I would easily be willing to drop $15 to $20 on a transcode plugin for MB Classic that taps into the transcoding capabilities of MB Server. This would also avoid lock ups or problems and allow extender users to use the new custom player interface. The current playback transcoding issues under WMC from Microsoft is what constantly make the box lock up. 360's are about to hit the $99 price point here soon and can already be snagged at the price point used. Unfortunately I don't have a solution to enjoy the GUI beauty of MB Classic on extender while enjoying the video playback you would get from the stock Xbox video player. This is not a new issue, just google it, been going on since the Vista days and Microsoft just dont care. Edited November 4, 2014 by BAS 2
Wilky13 21 Posted November 5, 2014 Author Posted November 5, 2014 It sucks that Microsoft is abandoning WMC. It really is a great program to integrate LiveTV, Recorded and downloaded TV (with Recorded TV HD), music, and large movie collections (with MB3). Microsoft obviously knows the Xbox 360 can direct play mp4 (with H264 & AAC) as proof with its Xbox Video Player. It blows my mind that they make the WMC interface transcode the SAME EXACT files! Whatever the stock video player can do should be mirrored in WMC extender. @@BAS, thanks for the info. I will tweak my network settings. But if the underlying problem is that WMC is transcoding the only true solution is for there to be a way to tell it to direct play and NOT transcode. But like you said, no codec or registry tweak has been found. 1
Wilky13 21 Posted November 6, 2014 Author Posted November 6, 2014 Well I found someone over on the Plex forums who says his mp4's do NOT transcode when he plays them through WMC on his Xbox 360 extenders. I originally found his post here: https://forums.plex.tv/index.php/topic/87245-xbox-one-dlna-problems/ Then PMed him to confirm. He says his mp4's direct play to his Xbox inside WMC. However, he does not have any codec packs installed on his HTPC. Just straight up Windows 8 (also did the same on Windows 7). So I wonder if having LAV installed in order to bitstream audio on the main HTPC throws the Xbox for a loop when it ties to play a file inside of WMC. Maybe it sees the 'LAV Audio Decoder' instead of 'Microsoft Audio Decoder' and doesn't know what to do and starts transcoding? Below you can see my GraphStudio render for the file in question on the HTPC. When I play the file on the HTPC you can see the white LAV Splitter and blue LAV Audio icons in the task tray. When I play the file on the Xbox through WMC, those icons do not appear on the HTPC. Anyone have a vanilla version of Windows 7 that can confirm this? I really don't want to uninstall LAV just to test. Because I do use it on the HTPC to bitstream.
BAS 225 Posted November 6, 2014 Posted November 6, 2014 Oh! I have a Win7 Professional 64-bit laptop that has no codecs on it. I will uninstall an extender from the HTPC and attach it to that. And do some testing, also. Unfortunately, I have to wait for my wife to go to bed. She gets angry wen I mess with her ability to watch TV on the extenders! I know that feeling all to well. 1
Wilky13 21 Posted November 6, 2014 Author Posted November 6, 2014 Oh! I have a Win7 Professional 64-bit laptop that has no codecs on it. I will uninstall an extender from the HTPC and attach it to that. And do some testing, also. Unfortunately, I have to wait for my wife to go to bed. She gets angry wen I mess with her ability to watch TV on the extenders!
BAS 225 Posted November 6, 2014 Posted November 6, 2014 Interesting, yep back in the day I never used lav filters for playback of course, now it was all I installed. I can't promise I can get to uninstalling that today and testing but I will do it tomorrow for sure. If thats the case then its back to a problem for a hosting pc like yours that is actually used as a htpc as well. My hosting PC is my Windows 7 PC that isnt used for HTPC so I will mess around with no codecs to see if i get better results.
BAS 225 Posted November 6, 2014 Posted November 6, 2014 Yep and trust me I've spent years of research on this subject even back to the days when this project was known as Videobrowser I would love to have better video quality on the extender experience with my own files. I know I can get better quality from DLNA but I much prefer the GUI which is why I spent years helping with themes and such. Hopefully whatever the team is working on for official Xbox app solutions will be awesome. 1
Wilky13 21 Posted November 6, 2014 Author Posted November 6, 2014 (edited) Interesting, yep back in the day I never used lav filters for playback of course, now it was all I installed. I can't promise I can get to uninstalling that today and testing but I will do it tomorrow for sure. If thats the case then its back to a problem for a hosting pc like yours that is actually used as a htpc as well. My hosting PC is my Windows 7 PC that isnt used for HTPC so I will mess around with no codecs to see if i get better results. "If" this is true it may prompt me to split my HTPC/Server in to 2 separate systems. Of course I was about to build a workhorse i7 hackintosh. Maybe I'll end up building a server instead! Edit: posted on TGB. http://www.thegreenbutton.tv/forums/viewtopic.php?f=8&t=8095 Edited November 5, 2014 by Wilky13
Wilky13 21 Posted November 6, 2014 Author Posted November 6, 2014 (edited) Good or Bad news depending on how you look at it. When I connect the 360 to the Win7 Professional 64-bit (that has no codecs on it) and play the file it looks much better! It looks almost as good as on the PC, but the slight variation may be due to the not as nice TV as on the HTPC or just the Xbox itself. But it is DEFINITELY way better than when connected to the HTPC with LAV installed. CPU load does go from about 7-8% to 17-18% though? Is it still transcoding or is that just overhead to stream the direct feed? Is there a way to tell on the PC if it is transcoding a file or not? edit: removed the stuff about the extenders connection (not relevant to this thread) Edited November 7, 2014 by Wilky13
Wilky13 21 Posted November 7, 2014 Author Posted November 7, 2014 (edited) This is year 4 since I was introduced to HTPC's and built my own in early 2011... and been tweaking ever since! Originally I used MKV files because it was an easy container to deal with (you can put anything in a MKV)! And installed Shark007 codec pack and was done (I even wrote some guides for Assassin'a blog). But then I got 2 Xbox 360's for less than $99 each to use as extenders and the fun began! MKV's don't play well on the extenders. So I remuxed what I could and transcoded the rest (400+ movies in all) to M2TS. M2TS works better on the 360's but on the main HTPC you can't play subtitles nor get Windows to give up control of audio to bitstream (I eventually did with a lot of tweaking). Somewhere along the way I got Plex and like that for streaming to my iPhone while I am at the gym. Then the MB team released MB3 (I had used MB2 from the beginning). Then last year I got a 2008 Mac Pro from a friend for $500 and the adventure began again to make everything "Mac Friendly"! My wife and I already had iPads and iPhones and the kids have iPods so it made sense. So I've spent the past months remuxing the H.264 M2TS movies to MP4 and transcoding the non-H.264 to MP4. Dump them all into iTunes on the Mac and now they are available on the AppleTV3 (got that for Christmas). Half way through I realized I should also add AAC Stereo tracks to every movie so I can easily drop it to the iPads/iPods/iPhones and go. I had just moved so I decided to do a clean install (I'm sure all the tweaking had broken a lot) on my Win7 HTPC and just install LAV instead of the full Shark007 pack and used Win7DSFiletTweaker to allow LAV to control MP4 containers vice Windows. I also installed MBS, MBC and RecordedTVHD (great program BTW for seamlessly integrated recorded TV, downloaded TV, converted TV in one place). I thought I was finally done, but then that's when I noticed the really poor video quality when watching the movies on the extenders, and thus this thread was born. I still have about 2TB of TV Shows in MKV format. But for now I want to solve the Movies issue. As I said before all the movies are now in a MP4 container with H.264 video and 2-ch AAC audio (the majority of them also have a 2nd 5.1 AC-3 track and a few have a 3rd 5.1 DTS track). So far we have confirmed that the HTPC is transcoding the movie resulting in the poor video quality on the Xbox 360 in WMC (files play fine in the Video App). Connecting the 360 to a 'clean' PC with no codecs revealed the movie will direct play in WMC thus providing good video quality. So the question is what has been added on the HTPC, as compared to the clean PC, to break this? It must be either LAV or the changing of merits in Win7DSFilterTweaker. Edited November 7, 2014 by Wilky13
BAS 225 Posted November 7, 2014 Posted November 7, 2014 (edited) Good or Bad news depending on how you look at it. When I connect the 360 to the Win7 Professional 64-bit (that has no codecs on it) and play the file it looks much better! It looks almost as good as on the PC, but the slight variation may be due to the not as nice TV as on the HTPC or just the Xbox itself. But it is DEFINITELY way better than when connected to the HTPC with LAV installed. CPU load does go from about 7-8% to 17-18% though? Is it still transcoding or is that just overhead to stream the direct feed? Is there a way to tell on the PC if it is transcoding a file or not? Bad news is the Extender keeps disconnecting from the PC every 2-3 minutes (whether it is playing something or just sitting at the main screen). It gives this error for some reason (I even rebooted the PC and left it at the logon screen and the extender still connects to WMC but then looses connection): Very interesting I've been suffering from some major hardware issues over here lately so I'm currently in the middle of a complete rebuild and low level format on my ssd. I will be attempting no codecs to see if all my file formats play, I'm sure i have stuff that will require codecs and break stuff though but obviously taken the lazy way with LAV filters is not what I need for extenders I still have in use. I would imagine the disconnect to be a properly shared path, or sleep setting on the pc somewhere. I haven't really done no codecs in a long time, but for my needs it would be fantastic from this pc as its not a playback unit. The old trusted thing for me back in the day was the divx codec pack with ac3 filter but tried a ton of other solutions its all a matter of sacrificing one thing for another it always felt. We shall see what path I take, I have mp4 h264 with 2 ch aac, m2ts h264 with 5.1 ac3, and a ton of avi xvid with 2ch mp3. If I can play all this without codecs then that's where Ill stop. Thanks for looking into it. As for if its transcoding or not, I would watch the CPU load on wmplayer, wmpnetwork as well, if they eventually subside if thats the case then i would say yes it is transcoding. You should also be able to check in windows media player for settings related to the transcode path and quality settings. Once i get back up and running I'll check back in. Edited November 6, 2014 by BAS 1
BAS 225 Posted November 7, 2014 Posted November 7, 2014 Well I'm probably not going to go much further down the experimenting path with you as I'm back up and running and will probably set it. Here's what I have discovered, I started on my 360 by deleting the optional media update and reaquiring with a free Xbox Live silver account from here or on the console just make sure you snag the one from 2011. I tested mp4 h264 2ch aac content and it played looked real nice, my m2ts h264 ac3 files choked, avi xvid mp3 looked decent but a little skippy in high frame rate scenes. I'm having flashback of video browser days.. Installing LAV Filters only I noticed my h264 content on extenders became fuzzy and pixelated but ac3 audio content worked, avi's looked about the same. I saw your post and even though I setup LAV to open everything, when I checked Win 7 DS Filter tweaker it reported everything was still set to Microsoft. I stopped there and uninstalled LAV, video quality is back on extenders. If your hosting on a 64 bit windows install everything codecs side for extenders runs on the 64bit side. So perhaps if you setup a 32bit player for LAV to handle stuff PC wise and then 64 bit all set to default Microsoft but thats going to require experimenting on your part. What I have done to keep decent H264 plaback on extenders is install the DIVX codec pack, not the Divx 10 bundle. Took me a long time to find that direct link in a forum post on Divx Labs. It was worth the digging installed, codec pack was only choice, be careful there was one ad to decline. Went into the divx codec settings app and turned on dxva hardware options. Tested same h264 mp4 aac and it looked exactly the same, my m2ts h264 looked sharper but ac3 still was an issue. The avi's looked a tad improved but they need replaced. I then went back to my old standby on ac3 sound for PC and 360's- AC3 Filter . If your using 64 bit you need full, set that up leaving on default options. All my files now play on my extenders and at better video quality then with LAV Filters. Not sure how much that helps you. All I know is that you pointing out that LAV might be the culprit for low quality h264 playback on extenders is right on the money in my opinion.
Wilky13 21 Posted November 8, 2014 Author Posted November 8, 2014 Okay, unassociating MP4 files with Media Foundation (so that LAV has control) on the PC is the culprit. When you check MP4 on the PC the quality on the extender goes bad. If you uncheck MP4 the quality goes back up. I guess this makes sense. It looks like LAV only "runs" on the PC. So when you call up a MP4 on the extender and it doesn't see that file type associated with media foundation it transcodes it. Time to move over to the LAV forum and see if they can come up with a way for when you install LAV it runs on the host PC as well as any extenders.
BAS 225 Posted November 8, 2014 Posted November 8, 2014 (edited) Well keep me posted on what you get, I'll be interested in your findings or a solution from them. Right now I'm happy with what I got going on, divx does the mkv's if i ever forget to clean one and don't really feel like going any further just cause I have been down the registry tweaking and all this before. Ill accept where I'm at, another thing that usually breaks when tweaking is resuming capabilities just a heads up as another to keep an eye on when checking playback. Edited November 7, 2014 by BAS
Wilky13 21 Posted November 8, 2014 Author Posted November 8, 2014 (edited) BAS, Hmmm..... my troubleshooting has resulted in a different outcome. I installed LAV on the PC and the video quality on the extenders is still good! So it is NOT LAV as I had thought. My next step is to do the Filter Tweaks and see if that is the cause. 1) No codecs at all on PC = good H.264 MP4 video on extender. 2) LAV installed on the PC = good H.264 MP4 video on extender. 3) Use Win7DSFiletTweaker to force Windows to associate MP4 with LAV = ???? Sidenote: MKVs also played nice on the extender (after doing the REG tweak here Just do the reg hack don't install all the codecs [other than LAV of course]). Edited November 7, 2014 by Wilky13
Wilky13 21 Posted November 8, 2014 Author Posted November 8, 2014 (edited) Yeah, the reason I did a clean install is because I was tired of trading one fix for another and installing/uninstalling codec after codec. I am going to stick with MP4s because that is what world best for Mac (OS X, iOS). I want very little on my HTPC other than what is needed to bitstream, so that means just LAV. It looks like the solution for now is to have a Media Server running Windows 7 and MBS, with the extenders tied to it. (I was contemplating WHS2011, but you can't connect extenders to it) And then a separate HTPC with MBC and WMC (no extenders tied to it). I will post over on the LAV and TGB forums to see if there will eventually be a solution for LAV to work on the extenders and stop the transcoding. TGB: http://www.thegreenbutton.tv/forums/viewtopic.php?f=8&t=8104&p=82413#p82413 LAV: https://code.google.com/p/lavfilters/issues/detail?id=500&thanks=500&ts=1415396859 Edited November 7, 2014 by Wilky13 1
