mohoelx 12 Posted May 2, 2023 Posted May 2, 2023 So this may be "normal" but it was a surprise to me, so I thought I'd share. I have a Library that contains two libraries; E:\HDHR which contains E:\HDHR\TV and E:\HDHR\Movies I have them all set to extract thumbnails, but was not getting them on the movies nor TV programs in the 'subfolder' libraries. I removed the E:\HDHR "parent folder" library, leaving the two "subfolder" libraries (now each as stand-alone libraries), and the thumbnails generated as expected. Not sure why if a library is contained within a library it would not be acted upon, but there you go. Note - the only reason I had done it that way was everything in these libraries was duplicates as I experiment with a new tuner device, and wanted to limit how much real estate it was taking on the "home" screen. Not really a big deal, but not getting the thumbnails was an unexpected outcome for me. Thanks again for Emby!
GrimReaper 4847 Posted May 2, 2023 Posted May 2, 2023 Not sure I understood your setup: 47 minutes ago, mohoelx said: I have a Library that contains two libraries; E:\HDHR which contains E:\HDHR\TV and E:\HDHR\Movies Is that a library with 2 folders or you used those same folders for two separate libraries?
mohoelx 12 Posted May 2, 2023 Author Posted May 2, 2023 So on Windows file system, it is a folder with two subfolders. In Emby, I had all 3 defined as Libraries. So from Emby, I suppose, it was two Libraries within a Library. It would appear to me that the Thumbnail extraction was only 'seeing' the E:\HDHR library, and not the two within it. Perhaps there concept of a "library within a library" is totally out of bounds....
Solution GrimReaper 4847 Posted May 2, 2023 Solution Posted May 2, 2023 14 minutes ago, mohoelx said: Perhaps there concept of a "library within a library" is totally out of bounds Correct. Currently library within a library - library which has a path that is subset of another library path - is not supported, library paths must be at least same-level folders.
