tunja74 1 Posted May 2, 2023 Posted May 2, 2023 Hallo Leute. Ich bin neu hier und habe ein Problem. Ich habe eine Idiche Serie (Jodha Akbar) diese Serie hat nur eine Staffel, aber mit knapp 400 folgen. Emby erken bis fole 99 was danach kommt, ist alles flasch. Was kann ich machen damit alles richtig erkannt wirt?.
GrimReaper 4896 Posted May 2, 2023 Posted May 2, 2023 How are your files named and organized and what are your library enabled meta-providers and in what order?
tunja74 1 Posted May 2, 2023 Author Posted May 2, 2023 Jodha Akbar (2013)/staffel 1/jodha Akbar s01e01.mkv Meta Anbieter: TVDB So hab ich das organisiert.
GrimReaper 4896 Posted May 2, 2023 Posted May 2, 2023 (edited) 8 hours ago, tunja74 said: Jodha Akbar (2013)/staffel 1/jodha Akbar s01e01.mkv Meta Anbieter: TVDB So hab ich das organisiert. TVDB lists only 286 episodes for that show. https://thetvdb.com/series/jodha-akbar/seasons/official/1 TMDB has 565. https://www.themoviedb.org/tv/60580-jodha-akbar/season/1 Enable TMDB provider and put it on top of your library preferred scrapers, re-Identify the show, lock the item afterwards, revert TVDB on top. Edited May 2, 2023 by GrimReaper Append
Luke 42240 Posted May 2, 2023 Posted May 2, 2023 Does your file naming more closely match TVDB or TMDB? Please note that putting TMDB at the top may cause problems with other shows so you need to choose that carefully depending on how your shows are named.
GrimReaper 4896 Posted May 2, 2023 Posted May 2, 2023 (edited) 8 minutes ago, Luke said: Does your file naming more closely match TVDB or TMDB? Please note that putting TMDB at the top may cause problems with other shows so you need to choose that carefully depending on how your shows are named. It is not Identify problem, it is (not available on TVDB) metadata problem. OP has 400 episodes. TVDB lists 286 only. TMDB has 565 of them. Edited May 2, 2023 by GrimReaper
tunja74 1 Posted May 2, 2023 Author Posted May 2, 2023 (edited) Hallo Luke. Danke für deine Antwort, ich habe TVDB AN DER Spitze gesetzt. Und die Benennung wie oben schon beschrieben. Jodha Akbar (2013)/staffel 1/Jodha Akbars01e01.avi. Wen ich aber An die s01e100 komme zeigt er mir nichts an. Wen ich s01e101 schreibe macht Emby daraus. S01e01, Wen ich s01e201 mache erstellt Emby daraus s02e01. Und genau das ist mein Problem. Edited May 2, 2023 by tunja74
Luke 42240 Posted May 2, 2023 Posted May 2, 2023 OK i see what you're saying, that the episode number is being wrongly interpreted. Good news - i just tested this on the 4.8 beta server and i could not reproduce, so I think this will be improved with the next release of the server.
