lewisken02 2 Posted May 4, 2025 Posted May 4, 2025 I also experiencing this, but clearing data/cache seems to work.
sa2000 697 Posted May 5, 2025 Posted May 5, 2025 (edited) On 04/05/2025 at 11:18, lewisken02 said: but clearing data/cache seems to work. Yes - appears to be some residual data after a failure that is stopping the ready to download items to be downloaded The issue is under investigation - there have already been some fixes in the latest beta of the Emby for Android app - see release notes for 3.4.66 and 3.4.67 Edited May 5, 2025 by sa2000 1
lewisken02 2 Posted May 23, 2025 Posted May 23, 2025 Hopefully will be resolve in the future release. I am in version 3.4.67 on Emby Android, but it is still reoccurring. I don't want to delete all of my downloads just to fix this. On 05/05/2025 at 21:03, sa2000 said: Yes - appears to be some residual data after a failure that is stopping the ready to download items to be downloaded The issue is under investigation - there have already been some fixes in the latest beta of the Emby for Android app - see release notes for 3.4.66 and 3.4.67 1
sa2000 697 Posted May 23, 2025 Posted May 23, 2025 10 hours ago, lewisken02 said: , but it is still reoccurring Are you referring to download jobs created on Emby for Android version 3.4.65 and earlier ? Or is this happening for new download jobs using 3.4.67 or later? 10 hours ago, lewisken02 said: I don't want to delete all of my downloads just to fix this. What about only deleting the download job that has the issue and see if that resolves the problem Do you have adb available to access the android storage - so i can check if there are residual download files
Mattman3234 5 Posted May 24, 2025 Posted May 24, 2025 I'm updated to the latest beta of the android app and tried deleting the series that was stuck at ready to transfer and then downloading again and the same 2 of 5 episodes are stuck at ready to transfer. I don't have adb to check the storage location. Happy to try anything else. 1
lewisken02 2 Posted May 28, 2025 Posted May 28, 2025 On 23/05/2025 at 23:34, sa2000 said: Are you referring to download jobs created on Emby for Android version 3.4.65 and earlier ? Or is this happening for new download jobs using 3.4.67 or later? What about only deleting the download job that has the issue and see if that resolves the problem Do you have adb available to access the android storage - so i can check if there are residual download files How do i check adb for residual download files?
sa2000 697 Posted May 29, 2025 Posted May 29, 2025 (edited) 10 hours ago, lewisken02 said: How do i check adb for residual download files? Attach phone through USB to a PC On the phone settings, enable developer options and within that, enable USB debugging On the PC in command line session, use adb - assuming you have installed the android platform tools. Run "adb devices" to see the devices. If you do not see the phone, unplug the usb and plug ir back and also toggle the USB Debugging option. Acknowledge and approve the debugging option prompts that pop up on the phone Once the device is showing on the PC in response to adb devcies, example: C:\Users\SA>adb devices List of devices attached R58M64B2YSB device 192.168.1.116:5555 device 192.168.1.219:5555 unauthorized here in this example samsung phone with ID "R58M64B2YSB" is the usb connected devices Then you can run adb commands to interrogate the phone and get info from it So to see if there are any residual episode files, you need to go to shell - so in example below this is for my phone - change the ID to be that for your phone This takes you to shell adb -s R58M64B2YSB shell you now have the linux shell commands availble to you, eg pwd In Shell Change directory to where the Download files are stored cd /storage/emulated/0/Android/data/com.mb.android/files/Download now you can drill through, using ls and cd commands To exit from shell, type exit Edited May 29, 2025 by sa2000
lewisken02 2 Posted May 30, 2025 Posted May 30, 2025 On 29/05/2025 at 15:54, sa2000 said: Attach phone through USB to a PC On the phone settings, enable developer options and within that, enable USB debugging On the PC in command line session, use adb - assuming you have installed the android platform tools. Run "adb devices" to see the devices. If you do not see the phone, unplug the usb and plug ir back and also toggle the USB Debugging option. Acknowledge and approve the debugging option prompts that pop up on the phone Once the device is showing on the PC in response to adb devcies, example: C:\Users\SA>adb devices List of devices attached R58M64B2YSB device 192.168.1.116:5555 device 192.168.1.219:5555 unauthorized here in this example samsung phone with ID "R58M64B2YSB" is the usb connected devices Then you can run adb commands to interrogate the phone and get info from it So to see if there are any residual episode files, you need to go to shell - so in example below this is for my phone - change the ID to be that for your phone This takes you to shell adb -s R58M64B2YSB shell you now have the linux shell commands availble to you, eg pwd In Shell Change directory to where the Download files are stored cd /storage/emulated/0/Android/data/com.mb.android/files/Download now you can drill through, using ls and cd commands To exit from shell, type exit I've check, but there's no residual files.This is a new download, converted to 4mbps and its stuck in Ready To Transfer.
lewisken02 2 Posted May 31, 2025 Posted May 31, 2025 I am on Android v3.40.70 the latest that i can update on Google Playstore. I tried another media, this time it's a series. Same 4mbps quality and it is transferring. I am now retrying the same movie i am having a hard time downloading, converting it to 12mbps quality. Still stuck in ready to transfer but i am able to play it fine.
sa2000 697 Posted May 31, 2025 Posted May 31, 2025 5 hours ago, lewisken02 said: Still stuck in ready to transfer but i am able to play it fine. status shows as ready to transfer but already downloaded and can be played on the android device in Downloads when offline? If the issue is reprodcible, enable logging on the Android app and also have debug logging enabled on the emby server (see settings / logs) and for the test start afresh by re-launch of the server and the android app and when the problem arises and confirmed, note down the time and details of what being downloaded and get screenshots and then download the logs from both the server and the android app and attach here
lewisken02 2 Posted May 31, 2025 Posted May 31, 2025 1 hour ago, sa2000 said: status shows as ready to transfer but already downloaded and can be played on the android device in Downloads when offline? If the issue is reprodcible, enable logging on the Android app and also have debug logging enabled on the emby server (see settings / logs) and for the test start afresh by re-launch of the server and the android app and when the problem arises and confirmed, note down the time and details of what being downloaded and get screenshots and then download the logs from both the server and the android app and attach here Nope, ready to transfer but not yet downloading/downloaded. No notification in phone that it is downloading. Okay i will do that. Thank you!
lewisken02 2 Posted May 31, 2025 Posted May 31, 2025 11 hours ago, sa2000 said: status shows as ready to transfer but already downloaded and can be played on the android device in Downloads when offline? If the issue is reprodcible, enable logging on the Android app and also have debug logging enabled on the emby server (see settings / logs) and for the test start afresh by re-launch of the server and the android app and when the problem arises and confirmed, note down the time and details of what being downloaded and get screenshots and then download the logs from both the server and the android app and attach here This is the start of conversion to lower quality. I started the download on 18:26, Nowhere Special is the title. Quote 2025-05-31 18:26:20.995 Info VideoEncoder: ProcessRun 'Encoding e942de' Execute: /bin/ffmpeg -loglevel +timing -y -print_graphs_file "/config/logs/ffmpeg-transcode-e942dee0-b47e-41bc-9141-6e2ae68d254a_1graph.txt" -copyts -start_at_zero -init_hw_device "vaapi=dev1:/dev/dri/renderD128" -f mp4 -c:v:0 h264 -threads:v:0 1 -hwaccel:v:0 vaapi -hwaccel_device:v:0 dev1 -hwaccel_output_format:v:0 vaapi -noautorotate -i "/storage/ceph/cMovie/cMovie2/Nowhere Special (2021)/Nowhere Special (2021) (tt11286640) [Bluray-1080p.AAC.x264.SCARE].mp4" -filter_complex "[0:0]scale_vaapi@f1=w=1280:h=692[f1_out0]" -map [f1_out0] -map 0:1 -map 0:2 -sn -c:v:0 h264_vaapi -b:v:0 3107482 -g:v:0 144 -maxrate:v:0 3107482 -bufsize:v:0 6214964 -keyint_min:v:0 144 -r:v:0 24 -profile:v:0 main -c:a:0 copy -metadata:s:a:0 language=eng -disposition:a:0 default -c:a:1 copy -metadata:s:a:1 language=eng -disposition:a:1 0 -avoid_negative_ts disabled -map_metadata -1 -map_chapters -1 "/config/sync/131/794/e942dee0-b47e-41bc-9141-6e2ae68d254a.mkv" embyserver.txt emby_android_1748707517386 (1).txt
sa2000 697 Posted June 2, 2025 Posted June 2, 2025 On 31/05/2025 at 19:48, lewisken02 said: This is the start of conversion to lower quality. I started the download on 18:26, Nowhere Special is the title. Could you get me the previous android log. This log file is from Sun Jun 01 00:05:17 I need to also see the one covering 31 May from 18:00
lewisken02 2 Posted June 2, 2025 Posted June 2, 2025 5 hours ago, sa2000 said: Could you get me the previous android log. This log file is from Sun Jun 01 00:05:17 I need to also see the one covering 31 May from 18:00 I dont have the logs files for May 31.
sa2000 697 Posted June 2, 2025 Posted June 2, 2025 7 minutes ago, lewisken02 said: I dont have the logs files for May 31 Was that because you disabled debug logging on the android or was it not enabled when you started the download ? FYI As you have adb, you might find it easier to download all logs - using: adb -s xxxxxxxx /storage/emulated/0/Android/data/com.mb.android/files/logs/
sa2000 697 Posted June 2, 2025 Posted June 2, 2025 (edited) 14 minutes ago, lewisken02 said: I dont have the logs files for May 31. Another option, as i have the android log for 1st June from midnight, you could get me the emby server log for that period . Just in case there are clues on what the earlier issue was Edited June 2, 2025 by sa2000
lewisken02 2 Posted June 2, 2025 Posted June 2, 2025 10 minutes ago, sa2000 said: Another option, as i have the android log for 1st June from midnight, you could get me the emby server log for that period . Just in case there are clues on what the earlier issue was Should i just retry the whole process? I could do that.
sa2000 697 Posted June 2, 2025 Posted June 2, 2025 3 minutes ago, lewisken02 said: Should i just retry the whole process? I could do that This is for a specific movie ? Yes you could but have debug logging enabled on both server and android beforehand and start the repro with a fresh re-launch of both the server and the android app with debug logging enabled beforehand And before doing the download, use adb to get `ls -ail` directory listing in adb shell for the Download directory where movies download to adb -s xxxxxx shell and then in shell cd /storage/emulated/0/Android/data/com.mb.android/files/Download/Videos ls -ail and get screenshot or export text out of the command line window Save this and start the download test and when it gets stuck in ready state, get sceenshot and the logs from the server and the android and attach with the adb session log You could at this point do another adb shell check and capture that as well Please also confirm that under here there is only Videos and TV sub-directories (if TV series downloaded as well) cd /storage/emulated/0/Android/data/com.mb.android/files/Download ls -ail Thanks 1
