DePingus 2 Posted April 29, 2023 Posted April 29, 2023 Hi. I think I found a possible bug (or maybe this is a feature request). I created an overlay network with Nebula (kinda like Tailscale). It's using the 172 subnet while my normal network is using 10. So my Emby server has both a 10 and 172 ip address. I went to Network > LAN Networks and added ONLY my 10 networks there. I was expecting that now clients in the 172 network would be considered "remote". Unfortunately, they're not. Users that are NOT allowed remote connections can login from a 172 address. And they can also see the logins of users that are set to appear only on the local network login screen. Is there any way to get the 172 users to be treated as remote? 1
seanbuff 1356 Posted April 29, 2023 Posted April 29, 2023 Hi @DePinguswhat version of Emby Server are you running?
Solution Luke 42245 Posted April 29, 2023 Solution Posted April 29, 2023 This is resolved in the upcoming 4.8 server release. 1
DePingus 2 Posted April 29, 2023 Author Posted April 29, 2023 (edited) Luke is the best! I'm always in awe of the amount of community work you put into Emby. Thanks! Edited April 29, 2023 by DePingus 1
