musicmafia 38 Posted April 28, 2023 Posted April 28, 2023 I temporarily sorted my files (on desktop PC) by bucket, then went right back to sorting by name. I didn't touch or change anything else. When I went back to sort by name, my A-Z navigation disappeared (usually on the side of the screen). I also noticed the library is no longer ignoring "THE" as part of the file name and is putting all those in the T section. Before it ignored the THE and sorted by the remaining part of the movie name. Should these things happen on a simple file sort change? (Still displays normally via TV app, this only seems to be on the PC logging in as local host). How do I get the A-Z navigation back? How do I go back to the way it sorted the THE files before?
Solution GrimReaper 4847 Posted April 28, 2023 Solution Posted April 28, 2023 I'd say you've sorted by File Name - what you want is sort by Title. 1
musicmafia 38 Posted April 28, 2023 Author Posted April 28, 2023 (edited) 6 minutes ago, GrimReaper said: I'd say you've sorted by File Name - what you want is sort by Title. Hilarious! I KNEW it would be something stupid and simple. Looking now for the DUH face palm emoji! Feel free to delete my stupid thread Edited April 28, 2023 by musicmafia
musicmafia 38 Posted April 28, 2023 Author Posted April 28, 2023 PS I was attempting to sort by video codec to sort HEVC, h264, etc? is that same as bucket?
GrimReaper 4847 Posted April 28, 2023 Posted April 28, 2023 You can not sort by video codecs - only filter by them. 1
