bigalpha 1 Posted April 26, 2023 Posted April 26, 2023 I'm experiencing an issue similar to the OP in THIS THREAD. HWA seems to only work once per boot, and fails after a few minutes then falls back to software encoding. I managed to watch the video at the moment it crashes - the video essentially glitches out for a spit-second and then continues playing. The 'play back info' tab says that it is "recovering from playback error". I'm a linux novice, having only recently dived in. Attached are the complete log files, with the names annotated. I'm running Proxmox with emby in an LXC. I've tried both a Debian and Ubuntu OS with no change. Installed using this: bash -c "$(wget -qLO - https://github.com/tteck/Proxmox/raw/main/ct/emby.sh)" This comes from tteck: https://tteck.github.io/Proxmox/ CPU: 11th Gen Intel(R) Core(TM) i5-11320H Privileged container I have HWA set up in a separate Plex container and it works with no issues Tried VAAPI and Quicksync codec in the Transcoding tab with no change On a fresh boot: Running vainfo in the host: root@Shipyard:~# vainfo error: can't connect to X server! libva info: VA-API version 1.10.0 libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/iHD_drv_video.so libva info: Found init function __vaDriverInit_1_10 libva info: va_openDriver() returns 0 vainfo: VA-API version: 1.10 (libva 2.15.0) vainfo: Driver version: Intel iHD driver for Intel(R) Gen Graphics - 21.1.1 () vainfo: Supported profile and entrypoints VAProfileNone : VAEntrypointVideoProc VAProfileNone : VAEntrypointStats VAProfileMPEG2Simple : VAEntrypointVLD VAProfileMPEG2Main : VAEntrypointVLD VAProfileH264Main : VAEntrypointVLD VAProfileH264Main : VAEntrypointEncSliceLP VAProfileH264High : VAEntrypointVLD VAProfileH264High : VAEntrypointEncSliceLP VAProfileJPEGBaseline : VAEntrypointVLD VAProfileJPEGBaseline : VAEntrypointEncPicture VAProfileH264ConstrainedBaseline: VAEntrypointVLD VAProfileH264ConstrainedBaseline: VAEntrypointEncSliceLP VAProfileVP8Version0_3 : VAEntrypointVLD VAProfileHEVCMain : VAEntrypointVLD VAProfileHEVCMain : VAEntrypointEncSliceLP VAProfileHEVCMain10 : VAEntrypointVLD VAProfileHEVCMain10 : VAEntrypointEncSliceLP VAProfileVP9Profile0 : VAEntrypointVLD VAProfileVP9Profile1 : VAEntrypointVLD VAProfileVP9Profile2 : VAEntrypointVLD VAProfileVP9Profile3 : VAEntrypointVLD VAProfileHEVCMain12 : VAEntrypointVLD VAProfileHEVCMain422_10 : VAEntrypointVLD VAProfileHEVCMain422_12 : VAEntrypointVLD VAProfileHEVCMain444 : VAEntrypointVLD VAProfileHEVCMain444 : VAEntrypointEncSliceLP VAProfileHEVCMain444_10 : VAEntrypointVLD VAProfileHEVCMain444_10 : VAEntrypointEncSliceLP VAProfileHEVCMain444_12 : VAEntrypointVLD VAProfileHEVCSccMain : VAEntrypointVLD VAProfileHEVCSccMain : VAEntrypointEncSliceLP VAProfileHEVCSccMain10 : VAEntrypointVLD VAProfileHEVCSccMain10 : VAEntrypointEncSliceLP VAProfileHEVCSccMain444 : VAEntrypointVLD VAProfileHEVCSccMain444 : VAEntrypointEncSliceLP VAProfileAV1Profile0 : VAEntrypointVLD VAProfileHEVCSccMain444_10 : VAEntrypointVLD VAProfileHEVCSccMain444_10 : VAEntrypointEncSliceLP Running vainfo in the lxc: root@emby:~# vainfo error: can't connect to X server! libva info: VA-API version 1.14.0 libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/iHD_drv_video.so libva info: Found init function __vaDriverInit_1_14 libva info: va_openDriver() returns 0 vainfo: VA-API version: 1.14 (libva 2.12.0) vainfo: Driver version: Intel iHD driver for Intel(R) Gen Graphics - 22.3.1 () vainfo: Supported profile and entrypoints VAProfileNone : VAEntrypointVideoProc VAProfileNone : VAEntrypointStats VAProfileMPEG2Simple : VAEntrypointVLD VAProfileMPEG2Main : VAEntrypointVLD VAProfileH264Main : VAEntrypointVLD VAProfileH264Main : VAEntrypointEncSliceLP VAProfileH264High : VAEntrypointVLD VAProfileH264High : VAEntrypointEncSliceLP VAProfileJPEGBaseline : VAEntrypointVLD VAProfileJPEGBaseline : VAEntrypointEncPicture VAProfileH264ConstrainedBaseline: VAEntrypointVLD VAProfileH264ConstrainedBaseline: VAEntrypointEncSliceLP VAProfileVP8Version0_3 : VAEntrypointVLD VAProfileHEVCMain : VAEntrypointVLD VAProfileHEVCMain : VAEntrypointEncSliceLP VAProfileHEVCMain10 : VAEntrypointVLD VAProfileHEVCMain10 : VAEntrypointEncSliceLP VAProfileVP9Profile0 : VAEntrypointVLD VAProfileVP9Profile1 : VAEntrypointVLD VAProfileVP9Profile2 : VAEntrypointVLD VAProfileVP9Profile3 : VAEntrypointVLD VAProfileHEVCMain12 : VAEntrypointVLD VAProfileHEVCMain422_10 : VAEntrypointVLD VAProfileHEVCMain422_12 : VAEntrypointVLD VAProfileHEVCMain444 : VAEntrypointVLD VAProfileHEVCMain444 : VAEntrypointEncSliceLP VAProfileHEVCMain444_10 : VAEntrypointVLD VAProfileHEVCMain444_10 : VAEntrypointEncSliceLP VAProfileHEVCMain444_12 : VAEntrypointVLD VAProfileHEVCSccMain : VAEntrypointVLD VAProfileHEVCSccMain : VAEntrypointEncSliceLP VAProfileHEVCSccMain10 : VAEntrypointVLD VAProfileHEVCSccMain10 : VAEntrypointEncSliceLP VAProfileHEVCSccMain444 : VAEntrypointVLD VAProfileHEVCSccMain444 : VAEntrypointEncSliceLP VAProfileAV1Profile0 : VAEntrypointVLD VAProfileHEVCSccMain444_10 : VAEntrypointVLD VAProfileHEVCSccMain444_10 : VAEntrypointEncSliceLP Running journalctl -b -o short-monotonic -k | egrep -i "i915|dmr|dmc|guc|huc" root@Shipyard:~# journalctl -b -o short-monotonic -k | egrep -i "i915|dmr|dmc|guc|huc" [ 1.709506] Shipyard kernel: i915 0000:00:02.0: vgaarb: deactivate vga console [ 1.710775] Shipyard kernel: i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=io+mem [ 1.711357] Shipyard kernel: i915 0000:00:02.0: [drm] Finished loading DMC firmware i915/tgl_dmc_ver2_12.bin (v2.12) [ 1.718076] Shipyard kernel: [drm] Initialized i915 1.6.0 20201103 for 0000:00:02.0 on minor 0 [ 3.082530] Shipyard kernel: fbcon: i915drmfb (fb0) is primary device [ 3.140438] Shipyard kernel: i915 0000:00:02.0: [drm] fb0: i915drmfb frame buffer device [ 6.254226] Shipyard kernel: snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915]) [ 6.280305] Shipyard kernel: mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915]) After playing a video and forcing transcoding Running vainfo in the host: root@Shipyard:~# vainfo error: can't connect to X server! libva info: VA-API version 1.10.0 libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/iHD_drv_video.so libva info: Found init function __vaDriverInit_1_10 Segmentation fault Running vainfo in the lxc: root@emby:~# vainfo error: can't connect to X server! libva info: VA-API version 1.14.0 libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/iHD_drv_video.so libva info: Found init function __vaDriverInit_1_14 libva info: va_openDriver() returns 0 vainfo: VA-API version: 1.14 (libva 2.12.0) vainfo: Driver version: Intel iHD driver for Intel(R) Gen Graphics - 22.3.1 () vainfo: Supported profile and entrypoints VAProfileNone : VAEntrypointVideoProc VAProfileNone : VAEntrypointStats VAProfileMPEG2Simple : VAEntrypointVLD VAProfileMPEG2Main : VAEntrypointVLD VAProfileH264Main : VAEntrypointVLD VAProfileH264Main : VAEntrypointEncSliceLP VAProfileH264High : VAEntrypointVLD VAProfileH264High : VAEntrypointEncSliceLP VAProfileJPEGBaseline : VAEntrypointVLD VAProfileJPEGBaseline : VAEntrypointEncPicture VAProfileH264ConstrainedBaseline: VAEntrypointVLD VAProfileH264ConstrainedBaseline: VAEntrypointEncSliceLP VAProfileVP8Version0_3 : VAEntrypointVLD VAProfileHEVCMain : VAEntrypointVLD VAProfileHEVCMain : VAEntrypointEncSliceLP VAProfileHEVCMain10 : VAEntrypointVLD VAProfileHEVCMain10 : VAEntrypointEncSliceLP VAProfileVP9Profile0 : VAEntrypointVLD VAProfileVP9Profile1 : VAEntrypointVLD VAProfileVP9Profile2 : VAEntrypointVLD VAProfileVP9Profile3 : VAEntrypointVLD VAProfileHEVCMain12 : VAEntrypointVLD VAProfileHEVCMain422_10 : VAEntrypointVLD VAProfileHEVCMain422_12 : VAEntrypointVLD VAProfileHEVCMain444 : VAEntrypointVLD VAProfileHEVCMain444 : VAEntrypointEncSliceLP VAProfileHEVCMain444_10 : VAEntrypointVLD VAProfileHEVCMain444_10 : VAEntrypointEncSliceLP VAProfileHEVCMain444_12 : VAEntrypointVLD VAProfileHEVCSccMain : VAEntrypointVLD VAProfileHEVCSccMain : VAEntrypointEncSliceLP VAProfileHEVCSccMain10 : VAEntrypointVLD VAProfileHEVCSccMain10 : VAEntrypointEncSliceLP VAProfileHEVCSccMain444 : VAEntrypointVLD VAProfileHEVCSccMain444 : VAEntrypointEncSliceLP VAProfileAV1Profile0 : VAEntrypointVLD VAProfileHEVCSccMain444_10 : VAEntrypointVLD VAProfileHEVCSccMain444_10 : VAEntrypointEncSliceLP Running journalctl -b -o short-monotonic -k | egrep -i "i915|dmr|dmc|guc|huc" root@Shipyard:~# journalctl -b -o short-monotonic -k | egrep -i "i915|dmr|dmc|guc|huc" [ 1.709506] Shipyard kernel: i915 0000:00:02.0: vgaarb: deactivate vga console [ 1.710775] Shipyard kernel: i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=io+mem [ 1.711357] Shipyard kernel: i915 0000:00:02.0: [drm] Finished loading DMC firmware i915/tgl_dmc_ver2_12.bin (v2.12) [ 1.718076] Shipyard kernel: [drm] Initialized i915 1.6.0 20201103 for 0000:00:02.0 on minor 0 [ 3.082530] Shipyard kernel: fbcon: i915drmfb (fb0) is primary device [ 3.140438] Shipyard kernel: i915 0000:00:02.0: [drm] fb0: i915drmfb frame buffer device [ 6.254226] Shipyard kernel: snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915]) [ 6.280305] Shipyard kernel: mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915]) [ 800.927888] Shipyard kernel: i915 0000:00:02.0: [drm] Resetting vcs0 for preemption time out [ 800.930868] Shipyard kernel: i915 0000:00:02.0: [drm] GPU HANG: ecode 12:4:28fffffd, in ffmpeg [4964] [ 809.315602] Shipyard kernel: i915 0000:00:02.0: [drm] GPU HANG: ecode 12:4:28fffffd, in ffmpeg [4964] [ 809.316626] Shipyard kernel: i915 0000:00:02.0: [drm] Resetting vcs0 for stopped heartbeat on vcs0 [ 809.318742] Shipyard kernel: i915 0000:00:02.0: [drm] Resetting chip for stopped heartbeat on vcs0 [ 809.423202] Shipyard kernel: [drm:__uc_sanitize [i915]] *ERROR* Failed to reset GuC, ret = -110 [ 809.532861] Shipyard kernel: i915 0000:00:02.0: [drm] *ERROR* Failed to reset chip [ 809.532885] Shipyard kernel: i915 0000:00:02.0: [drm:add_taint_for_CI [i915]] CI tainted:0x9 by intel_gt_reset+0x2f9/0x340 [i915] [ 809.636624] Shipyard kernel: [drm:__uc_sanitize [i915]] *ERROR* Failed to reset GuC, ret = -110 [ 809.642933] Shipyard kernel: i915 0000:00:02.0: [drm] ffmpeg[4964] context reset due to GPU hang [ 814.401837] Shipyard kernel: Fence expiration time out i915-0000:00:02.0:ffmpeg[4964]:162e! embyserver_after transcode crash.txt ffmpeg-transcode-fcd5deca-4aa6-4464-87ec-8404ae0239d7_1_after transcode crash.txt ffmpeg-transcode-632f9424-cbac-4643-a38e-c5f87dee3cb6_1_while transcoding.txt hardware_detection-63818060321.txt hardware_detection-63818060321_fresh boot.txt embyserver_fresh boot.txt
Luke 42245 Posted April 26, 2023 Posted April 26, 2023 Hi, for comparison purposes are you able to try installing directly onto the host machine?
bigalpha 1 Posted April 26, 2023 Author Posted April 26, 2023 Hi - and sorry for this potentially really dumb question... But since I'm using Proxmox I'm not sure what you mean by install it directly onto the host machine - I have everything in a VM or LXC container at the moment.
bigalpha 1 Posted April 27, 2023 Author Posted April 27, 2023 I'm wondering what drivers come in the emby package that are related to hardware acceleration. I'm wondering if they conflict somehow with the usage of quicksync.
Solution bigalpha 1 Posted April 27, 2023 Author Solution Posted April 27, 2023 Well I managed to resolve this issue. My Proxmox instance was on PVE kernel 5.15 which apparently has some kind of weird bug that can cause these symptoms. I upgraded the kernel to 6.1 and the i915 driver crash issue doesn't happen anymore. I ran two transcode streams simultaneously for quite a while with no issues.
Luke 42245 Posted April 27, 2023 Posted April 27, 2023 10 hours ago, bigalpha said: Well I managed to resolve this issue. My Proxmox instance was on PVE kernel 5.15 which apparently has some kind of weird bug that can cause these symptoms. I upgraded the kernel to 6.1 and the i915 driver crash issue doesn't happen anymore. I ran two transcode streams simultaneously for quite a while with no issues. Thanks for following up !
