hendrysetiadi 1 Posted April 25, 2023 Posted April 25, 2023 Why on emby android app cannot show full filename on library folder? It's hard to choose the song while all filename was cut. And is it possible to sort the folder by date created of file?
Luke 42239 Posted April 25, 2023 Posted April 25, 2023 Hi, can you please show a screenshot example? Thanks.
hendrysetiadi 1 Posted April 25, 2023 Author Posted April 25, 2023 Hi, here is the screenshot that describe it. And the other 2 screenshot i show you why on 1 folder the display different with when i browse that folder using file manager? Also the folder name was cut. Thanks Hendry
Luke 42239 Posted April 26, 2023 Posted April 26, 2023 Quote And is it possible to sort the folder by date created of file? Did you try clicking the sort button?
hendrysetiadi 1 Posted April 26, 2023 Author Posted April 26, 2023 (edited) 6 hours ago, Luke said: Did you try clicking the sort button? Yes.. i found the option to sort by date added on sort button. How about the long filename or long folder name issue? Edited April 26, 2023 by hendrysetiadi
Luke 42239 Posted April 27, 2023 Posted April 27, 2023 We'll take a look at it. Thanks for reporting.
hendrysetiadi 1 Posted April 27, 2023 Author Posted April 27, 2023 53 minutes ago, Luke said: We'll take a look at it. Thanks for reporting. this has been issued also on symfonium app.. same problem with long folder name or file name.. it cannot full display. thanks also for your support. i'll wait for any update on this issue. 1
Luke 42239 Posted June 26, 2023 Posted June 26, 2023 On 6/20/2023 at 6:02 AM, hendrysetiadi said: any update for this issue ? We, we are looking into improving this. Thanks.
hendrysetiadi 1 Posted July 1, 2023 Author Posted July 1, 2023 On 6/27/2023 at 1:02 AM, Luke said: We, we are looking into improving this. Thanks. when this issue will be improved ? any recent progress ?
