Roku and AV1 480P Displays 4x3 not 16x9 (NOT AN EMBY ISSUE)
tedfroop
For anyone ripping to 480P with AV1, your Roku may have an issue.  I tried the same video on PC and on the Android TV app and it displays 16X9 in both but on my  Roku Ultra it displays in a weird 4x3 format.
Again - not an Emby issue - just fair warning.
Video
Format : AV1
Format/Info : AOMedia Video 1
Format profile : Main@L3.0
Codec ID : av01
Duration : 1 h 43 min
Source duration : 1 h 43 min
Bit rate : 716 kb/s
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 2.25:1
Frame rate mode : Variable
Frame rate : 23.976 FPS
Minimum frame rate : 23.974 FPS
Maximum frame rate : 29.970 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.086
Stream size : 531 MiB (78%)
Source stream size : 531 MiB (78%)
Encoded date : 2023-04-21 10:52:31 UTC
Tagged date : 2023-04-21 10:52:31 UTC
Color range : Limited
Color primaries : BT.601 NTSC
Transfer characteristics : BT.709
Matrix coefficients : BT.601
Menus : 3
Codec configuration box : av1C
  • Thanks 1
Thanks for sharing.
  • Like 1
tedfroop
3 hours ago, Luke said:
Thanks for sharing.
No problem.  Always nice to find a quick answer if you have an issue.
  • Thanks 1
  • 1 month later...
tedfroop
Further info....its not a Roku issue but normal function for Sony K85 TV's.....
IF you have Dolby Vision on, 720x480 sources display in a weird 4x4 format.  Designed so you can't have Dolby Vision on while playing DVD's apparently.  (but buying new Blu Rays will work just fine....🤑)
So I'm up-converting files to 1280x720.....
  • Thanks 2
Thanks for following up.
