thorkillar 4 Posted April 15, 2023 Posted April 15, 2023 (edited) Moin in die Runde, ich frage mich schon seit einiger Zeit, wann und warum manche Filme/Serien transcodiert werden? Ist das vom Dateiformat oder Endgerät abhängig? Und was kann/muss ich tun, dass das Abspielen funktioniert? Und was kann ich machen, wenn die Folgen beim Transcodieren ständig hängen bleiben? DANKE Edited April 15, 2023 by thorkillar
GrimReaper 4896 Posted April 15, 2023 Posted April 15, 2023 3 hours ago, thorkillar said: ich frage mich schon seit einiger Zeit, wann und warum manche Filme/Serien transcodiert werden? Ist das vom Dateiformat oder Endgerät abhängig? Und was kann/muss ich tun, dass das Abspielen funktioniert? Have a read here: https://support.emby.media/support/solutions/articles/44001159897-transcoding Quote Why Is My Media Transcoding? Whenever possible, Emby apps will play your files directly and avoid transcoding. Transcoding will only be used when files are not natively supported by the device you're trying to play from, or the bitrate of the content is higher than the app's bitrate setting. Why Is My File Transcoding? First, compare the media format of your file to the format supported by the Emby app. You can find the media info in the Emby Web Client, at the bottom of the detail page: https://s3.amazonaws.com/cdn.freshdesk.com/data/helpdesk/attachments/production/2043015269037/original/Bfwxsd9ZHZ8S5HHH2rVKdVB-14Ld_A9srQ.png?1553707724 If the file is not natively supported, transcoding will be required. Next, compare the bitrate of your file to the bitrate setting in the app. You can find the bitrate of your file by checking the media info in the web interface. If the bitrate of the file is higher than the setting in the app, transcoding will be required. Increasing the bitrate setting in the app can help reduce transcoding, but may impact playback performance if your network connection is not fast enough to handle it. Emby apps are beginning to support automatic bitrate detection in order to automatically select the highest bitrate possible. Most users will see best results by leaving the bitrate setting on Auto. Lastly, are subtitles selected? If subtitles are selected, then this may trigger transcoding if the app does not natively support the subtitle format. Most Emby apps have native support for text-based subtitles (e.g. srt, vtt, etc). Graphical subtitles such as PGS and VobSub are more likely to trigger transcoding. To learn more about the formats that are natively supported by each Emby app, please visit the knowledge base section for that app: Amazon Fire TV Android Mobile Android TV Chromecast iOS Roku Web Client 3 hours ago, thorkillar said: Und was kann ich machen, wenn die Folgen beim Transcodieren ständig hängen bleiben? As noted in the above KB article: Quote My Files Shouldn't Be Transcoding. How Do I Report This? Start by focusing on a single example. Please report this in our community: http://emby.media/community/ Please make sure to supply the following information: A copy of the media info from the web interface The Emby Server log from the time you played the content The Emby Server transcoding logs from the same time (if any). Logs can be accessed directly within the server's web interface by navigating to Help -> Logs. Attach the information requested in how to report a media playback issue.
Solution thorkillar 4 Posted April 16, 2023 Author Solution Posted April 16, 2023 Sorry, ich habe den Artikel gelesen und glaube den Fehler gefunden zu haben. Ich habe die Hardwarebeschleunigung deaktiviert und seit dem funktioniert es. Ich werde es einige Tage testen und melde mich, wenn ich noch Probleme habe.
thorkillar 4 Posted April 16, 2023 Author Posted April 16, 2023 Kann ich den Beitrag als Gelöst markieren?
Luke 42240 Posted April 27, 2023 Posted April 27, 2023 On 4/16/2023 at 2:01 PM, thorkillar said: Kann ich den Beitrag als Gelöst markieren? I took care of it. What exactly did you disable?
thorkillar 4 Posted May 11, 2023 Author Posted May 11, 2023 (edited) Sorry für die späte Antwort. Ja kann als gelöst markiert werden. Die Lösung bei mir war, die Hardware-Beschleunigung auszuschalten. Ich hatte sie versehentlich aktiviert. Edited May 11, 2023 by thorkillar 1
