Dalpuri 22 Posted April 14, 2023 Posted April 14, 2023 I have an Emby server with two user accounts: one with admin access for myself, and another for public access within my home. However, the user with public access keeps changing the content orientation on the home screen, which is negatively impacting the experience for others. I would like to know if there is a way to revoke their access to customize the home screen settings so that they can't make any more changes. Additionally, I'm wondering if this change will also apply to Emby apps, or if separate settings will need to be adjusted for those. Thank you.
Luke 42290 Posted April 16, 2023 Posted April 16, 2023 Hi, there is currently no option for this, but yes, the homescreen options are shared for that user across all apps.
