nanohits 18 Posted April 14, 2023 Posted April 14, 2023 Hi All, I made a silly mistake of trying to use SSL with 8290 and forcing all remote connection to secure. Now I cant even get in. Is there a way in a config file I can reset it back to non SSL for port 8096? Any help would be appreciated
Luke 42245 Posted April 14, 2023 Posted April 14, 2023 HI, are you able to connect from inside your local network?
nanohits 18 Posted April 14, 2023 Author Posted April 14, 2023 It is ok, I managed to uninstall and re-install and manually added it and now it is all good. Thanks 1
