spon 26 Posted April 14, 2023 Posted April 14, 2023 (edited) Can someone please help me decode this error? I’m pretty clueless with network issues. I’m trying to connect Emby app on my Shield Pro to Emby server on windows computer. Both on same network via Ethernet. Thanks. 2023-04-13 17:29:16.623 Error PortMapper: Error creating port map *** Error Report *** Version: 4.7.11.0 Command line: C:\Users\BW\AppData\Roaming\Emby-Server\system\EmbyServer.dll -noautorunwebapp Operating system: Microsoft Windows 10.0.19045 Framework: .NET 6.0.10 OS/Process: x64/x64 Runtime: C:/Users/BW/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 4 Data path: C:\Users\BW\AppData\Roaming\Emby-Server Application path: C:\Users\BW\AppData\Roaming\Emby-Server\system System.Net.Http.HttpRequestException: System.Net.Http.HttpRequestException: No connection could be made because the target machine actively refused it. (192.168.1.1:52059) ---> System.Net.Sockets.SocketException (10061): No connection could be made because the target machine actively refused it. at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.ThrowException(SocketError error, CancellationToken cancellationToken) at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.System.Threading.Tasks.Sources.IValueTaskSource.GetResult(Int16 token) at System.Net.Sockets.Socket.<ConnectAsync>g__WaitForConnectWithCancellation|277_0(AwaitableSocketAsyncEventArgs saea, ValueTask connectTask, CancellationToken cancellationToken) at System.Net.Http.HttpConnectionPool.ConnectToTcpHostAsync(String host, Int32 port, HttpRequestMessage initialRequest, Boolean async, CancellationToken cancellationToken) --- End of inner exception stack trace --- at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at Mono.Nat.Upnp.UpnpNatDevice.CreatePortMapInternal(Mapping mapping, CancellationToken cancellationToken) at Mono.Nat.Upnp.UpnpNatDevice.CreatePortMap(Mapping mapping, CancellationToken cancellationToken) at Emby.PortMapper.ExternalPortForwarding.CreateRules(INatDevice device, CancellationToken cancellationToken) Source: Emby.Server.Implementations TargetSite: Void MoveNext() InnerException: System.Net.Sockets.SocketException: No connection could be made because the target machine actively refused it. Source: System.Net.Sockets TargetSite: Void ThrowException(System.Net.Sockets.SocketError, System.Threading.CancellationToken) at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.ThrowException(SocketError error, CancellationToken cancellationToken) at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.System.Threading.Tasks.Sources.IValueTaskSource.GetResult(Int16 token) at System.Net.Sockets.Socket.<ConnectAsync>g__WaitForConnectWithCancellation|277_0(AwaitableSocketAsyncEventArgs saea, ValueTask connectTask, CancellationToken cancellationToken) at System.Net.Http.HttpConnectionPool.ConnectToTcpHostAsync(String host, Int32 port, HttpRequestMessage initialRequest, Boolean async, CancellationToken cancellationToken) Edited April 14, 2023 by spon
GrimReaper 4848 Posted April 14, 2023 Posted April 14, 2023 (edited) You can disregard those for now, we'll come back to that if you want to setup remote access. 7 minutes ago, spon said: I’m trying to connect Emby app on my Shield Pro to Emby server on windows computer. Both on same network via Ethernet. You are trying - and not having success or? Have you gone through connectivity troubleshooter? https://support.emby.media/support/solutions/articles/44001849007-connectivity Edited April 14, 2023 by GrimReaper
spon 26 Posted April 14, 2023 Author Posted April 14, 2023 (edited) Thanks @GrimReaper. Apologies for not providing more information. Yes, I have gone through the troubleshooter. I can connect to the server fine from other PCs using any browser. I can also connect via iPad app. I'm just having issues with the Shield for some reason. I've tried with both the regular Shield Emby app, as well as a side loaded Android app. Even stranger, I can access the server on a different Shield in another room (also Ethernet connection). Edited April 14, 2023 by spon
GrimReaper 4848 Posted April 14, 2023 Posted April 14, 2023 (edited) 5 minutes ago, spon said: I can connect to the server fine from other PCs using any browser. I can also connect via iPad app. Good, that means server is accessible and ports open in firewall. 5 minutes ago, spon said: I'm just having issues with the Shield for some reason. I've tried with both the regular Shield Emby app, as well as a side loaded Android app. What kind of issues? Does the app see your server? Is it failing to connect? Are you unable to login? Have you tried connecting manually by entering server IP and port? Are your Shield and your server on the same subnet? Edited April 14, 2023 by GrimReaper
Solution spon 26 Posted April 14, 2023 Author Solution Posted April 14, 2023 (edited) I just figured it out in case someone runs across this post. My VPN (Windscribe) on the Shield is somehow blocking the local connection, even though I have it set to allow LAN connections. When I turn off the VPN, it works fine. Sorry for the wild goose chase. The issue itself was manifesting as the inability to connect to the server at all. Edited April 14, 2023 by spon
GrimReaper 4848 Posted April 14, 2023 Posted April 14, 2023 Glad you sorted it out. Though, if you've read troubleshooter: Quote Turn off any VPN Connections VPN (virtual private network) software can change routing and sometimes make connecting to servers on your home network impossible. This is especially true if when running a VPN on your Emby Server. If you're still unable to connect to your Emby server try turning off any VPN software running on any client or server in your home network.
spon 26 Posted April 14, 2023 Author Posted April 14, 2023 (edited) 14 minutes ago, GrimReaper said: Glad you sorted it out. Though, if you've read troubleshooter: I actually forgot I had the VPN turned on. It does make me wonder why having a VPN enabled on the client would prevent connection to the server (no VPN running). Frustrating because I either need to give up local streaming or VPN protection for other things. thanks so much for the super quick replies. Appreciate your help. Edited April 14, 2023 by spon 1
