quickmic 1709 Posted August 2, 2023 Posted August 2, 2023 7 hours ago, Loco007 said: I do also have Kodi Companion 2.2.1.0 installed on Emby if that makes any difference? No, that's not related to the issue. Thanks for the log, but nothing suspicious reported. Which Emby server version do you use? Is live tv working on Emby server?
Loco007 9 Posted August 2, 2023 Posted August 2, 2023 3 hours ago, quickmic said: No, that's not related to the issue. Thanks for the log, but nothing suspicious reported. Which Emby server version do you use? Is live tv working on Emby server? Livetv is working great in emby. Emby server version on my synology is 4.7.13.0-704071300 Using Emby app on my nvidia shield or s22 works perfect for LiveTV. On my Nvidia Shield I have tried:- Resetting the entire Shield and reinstalling everything Tried the latest stable & beta versions of Emby for Kodi Next Gen with the same result - selecting SyncLiveTV and nothing happens.
quickmic 1709 Posted August 3, 2023 Posted August 3, 2023 Does the user (plugin user for Emby server access) have permission to access livetv on Emby server? I'll send you a debug version in the next days.
Loco007 9 Posted August 3, 2023 Posted August 3, 2023 4 hours ago, quickmic said: Does the user (plugin user for Emby server access) have permission to access livetv on Emby server? I'll send you a debug version in the next days. Hi, are you referring to the user I login as in Kodi, and if that user has access to livetv in emby? Yes, the user I login as has full access to live tv in emby and I assume also from kodi once I login. If I have this wrong please let me know how I can check permission to access livetv? FYI - all users in my setup for emby have livetv access
quickmic 1709 Posted August 4, 2023 Posted August 4, 2023 Please install this version. Sync Live TV and send me the log, thanks. plugin.video.emby-next-gen-8.2.12 build 1 DEBUG.zip
Loco007 9 Posted August 4, 2023 Posted August 4, 2023 3 hours ago, quickmic said: Please install this version. Sync Live TV and send me the log, thanks. plugin.video.emby-next-gen-8.2.12 build 1 DEBUG.zip 6.58 MB · 2 downloads Thanks, installed and synced as requested. Please see log attached. All I had happen was kodi getting hung on 'creating PVR clients' but stuck on 0% and at the same time also stuck on 'PVR manager is starting up' and also stuck on 0%. kodi.log
quickmic 1709 Posted August 4, 2023 Posted August 4, 2023 Thanks for the log, seems there is something wrong on Emby server. There is no response for Emby server. I don't see a timeout in the log, but quite sure there will if you wait longer than 5 minutes. However, please upload an Emby server and a kodi.log including the sync for review.
Loco007 9 Posted August 6, 2023 Posted August 6, 2023 On 8/4/2023 at 10:09 PM, quickmic said: Thanks for the log, seems there is something wrong on Emby server. There is no response for Emby server. I don't see a timeout in the log, but quite sure there will if you wait longer than 5 minutes. However, please upload an Emby server and a kodi.log including the sync for review. Hi Quickmic, Have sent my logs directly to you thanks.
quickmic 1709 Posted August 7, 2023 Posted August 7, 2023 (edited) @Luke I reviewed Loco007's issue. The main problem was the lagy EPG queries. Loco has a huge amount of EPG data to be synced, the server query may take 2 minutes or even more. Depending on server load. I think there is room for improvement. As a workaround I increased the timeouts on client side and removed the totalcounts. But there is nothing else I could do. query is "LiveTv/Programs" with {'UserId': self.EmbyServer.ServerData['UserId'], 'Fields': "Overview", 'EnableTotalRecordCount': False) params Also tested without UserId, not much difference. Loaded 2003 channels Loaded 43 channel groups LoadChannelEpgs - Loaded '1278' EPG channels. LoadEpgEntries - Loaded '109111' EPG entries He runs a 4.7.13.0 Emby server on Synology. btw, I also tested with "/LiveTv/EPG", it doesn't respect the "fields" param Also I cannot perform a test on 4.8.X Emby server, I don't have such an amount of data. Edited August 7, 2023 by quickmic
Loco007 9 Posted August 8, 2023 Posted August 8, 2023 16 hours ago, quickmic said: @Luke I reviewed Loco007's issue. The main problem was the lagy EPG queries. Loco has a huge amount of EPG data to be synced, the server query may take 2 minutes or even more. Depending on server load. I think there is room for improvement. As a workaround I increased the timeouts on client side and removed the totalcounts. But there is nothing else I could do. query is "LiveTv/Programs" with {'UserId': self.EmbyServer.ServerData['UserId'], 'Fields': "Overview", 'EnableTotalRecordCount': False) params Also tested without UserId, not much difference. Loaded 2003 channels Loaded 43 channel groups LoadChannelEpgs - Loaded '1278' EPG channels. LoadEpgEntries - Loaded '109111' EPG entries He runs a 4.7.13.0 Emby server on Synology. btw, I also tested with "/LiveTv/EPG", it doesn't respect the "fields" param Also I cannot perform a test on 4.8.X Emby server, I don't have such an amount of data. Hi Luke, Any help or input would be much appreciated. Thanks.
Luke 42237 Posted August 9, 2023 Posted August 9, 2023 16 hours ago, Loco007 said: Hi Luke, Any help or input would be much appreciated. Thanks. Can you please provide the emby server log? thanks. 1
Loco007 9 Posted August 9, 2023 Posted August 9, 2023 5 hours ago, Luke said: Can you please provide the emby server log? thanks. Hi Luke, Sent my log directly to you, Thanks. 1
Luke 42237 Posted August 10, 2023 Posted August 10, 2023 On 8/9/2023 at 3:50 AM, Loco007 said: Hi Luke, Sent my log directly to you, Thanks. Looking into it. Thanks.
Luke 42237 Posted August 11, 2023 Posted August 11, 2023 On 8/9/2023 at 3:50 AM, Loco007 said: Hi Luke, Sent my log directly to you, Thanks. Can you temporarily enable debug logging on the server, then repeat the test and provide a new log? Also, your log is filled with messages such as this: 2023-08-09 18:34:26.054 Error ProviderManager: UnauthorizedAccessException: Emby Server is being write access to /volume1/docker/movies/The Adversary - (2002)/landscape.jpg. Please check your file permissions. You enabled saving images to media folders but did not grant the server write access to your media folders. So this is probably not helping your performance situation. I would either turn that off or fix it. 1
Loco007 9 Posted August 12, 2023 Posted August 12, 2023 On 8/11/2023 at 5:08 PM, Luke said: Can you temporarily enable debug logging on the server, then repeat the test and provide a new log? Also, your log is filled with messages such as this: 2023-08-09 18:34:26.054 Error ProviderManager: UnauthorizedAccessException: Emby Server is being write access to /volume1/docker/movies/The Adversary - (2002)/landscape.jpg. Please check your file permissions. You enabled saving images to media folders but did not grant the server write access to your media folders. So this is probably not helping your performance situation. I would either turn that off or fix it. Hi Luke, Thanks for that, ive updated permissions and messaged you my logs again, hopefully they show something, thanks 1
Luke 42237 Posted August 22, 2023 Posted August 22, 2023 What am I looking at in the latest log server file you provided? It's a nine minute log with not a lot of activity. And still these: 2023-08-13 09:29:57.298 Error ProviderManager: UnauthorizedAccessException: Emby Server is being write access to /volume1/docker/movies/Fading Gigolo - (2014)/poster.jpg. Please check your file permissions. They're harmless, the server will figure out what to do, but since you're mentioning performance it's worth bringing up.
Loco007 9 Posted August 23, 2023 Posted August 23, 2023 15 hours ago, Luke said: What am I looking at in the latest log server file you provided? It's a nine minute log with not a lot of activity. And still these: 2023-08-13 09:29:57.298 Error ProviderManager: UnauthorizedAccessException: Emby Server is being write access to /volume1/docker/movies/Fading Gigolo - (2014)/poster.jpg. Please check your file permissions. They're harmless, the server will figure out what to do, but since you're mentioning performance it's worth bringing up. Hi Luke, thanks for pointing this out, I've checked permissions and appears emby has read write permission for that shared 'docker' folder, is there anything else I'm missing for permissions?
Luke 42237 Posted August 23, 2023 Posted August 23, 2023 7 hours ago, Loco007 said: Hi Luke, thanks for pointing this out, I've checked permissions and appears emby has read write permission for that shared 'docker' folder, is there anything else I'm missing for permissions? Hi, where and how did you confirm this?
Loco007 9 Posted August 31, 2023 Posted August 31, 2023 On 8/24/2023 at 4:56 AM, Luke said: Hi, where and how did you confirm this? Hi Luke, confirmed through DMS on synology. Is there anywhere else I need to confirm this? Thanks
Luke 42237 Posted August 31, 2023 Posted August 31, 2023 2 minutes ago, Loco007 said: Hi Luke, confirmed through DMS on synology. Is there anywhere else I need to confirm this? Thanks Can you show a screenshot of what you confirmed? Thanks.
Loco007 9 Posted August 31, 2023 Posted August 31, 2023 1 hour ago, Luke said: Can you show a screenshot of what you confirmed? Thanks. No problem, here you go, and confirmed as both local and internal user.
Luke 42237 Posted September 7, 2023 Posted September 7, 2023 On 8/31/2023 at 5:07 PM, Loco007 said: No problem, here you go, and confirmed as both local and internal user. Are you using our native Synology package, or are you trying to run Docker on Synology?
Loco007 9 Posted September 7, 2023 Posted September 7, 2023 1 hour ago, Luke said: Are you using our native Synology package, or are you trying to run Docker on Synology? Using Native package:-
