hawk223 9 Posted April 10, 2023 Posted April 10, 2023 Hi I have converted most of my library to HEVC with AAC in mp4. I have some files that are failing so I tried them manually. I have attached the logs as well. Not sure if the audio channel warning is an issue but I can hear it but there is no video when I play it. Below is my conversion command and my probe command. What am I doing wrong? ffmpeg -i "Almost Human S01E01 Pilot.mkv" -c copy -map 0:v:0 -map 0:a:0 out.mp4 ffmpeg version 6.0-full_build-www.gyan.dev Copyright (c) 2000-2023 the FFmpeg developers built with gcc 12.2.0 (Rev10, Built by MSYS2 project) configuration: --enable-gpl --enable-version3 --enable-static --disable-w32threads --disable-autodetect --enable-fontconfig --enable-iconv --enable-gnutls --enable-libxml2 --enable-gmp --enable-bzlib --enable-lzma --enable-libsnappy --enable-zlib --enable-librist --enable-libsrt --enable-libssh --enable-libzmq --enable-avisynth --enable-libbluray --enable-libcaca --enable-sdl2 --enable-libaribb24 --enable-libdav1d --enable-libdavs2 --enable-libuavs3d --enable-libzvbi --enable-librav1e --enable-libsvtav1 --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs2 --enable-libxvid --enable-libaom --enable-libjxl --enable-libopenjpeg --enable-libvpx --enable-mediafoundation --enable-libass --enable-frei0r --enable-libfreetype --enable-libfribidi --enable-liblensfun --enable-libvidstab --enable-libvmaf --enable-libzimg --enable-amf --enable-cuda-llvm --enable-cuvid --enable-ffnvcodec --enable-nvdec --enable-nvenc --enable-d3d11va --enable-dxva2 --enable-libvpl --enable-libshaderc --enable-vulkan --enable-libplacebo --enable-opencl --enable-libcdio --enable-libgme --enable-libmodplug --enable-libopenmpt --enable-libopencore-amrwb --enable-libmp3lame --enable-libshine --enable-libtheora --enable-libtwolame --enable-libvo-amrwbenc --enable-libilbc --enable-libgsm --enable-libopencore-amrnb --enable-libopus --enable-libspeex --enable-libvorbis --enable-ladspa --enable-libbs2b --enable-libflite --enable-libmysofa --enable-librubberband --enable-libsoxr --enable-chromaprint libavutil 58. 2.100 / 58. 2.100 libavcodec 60. 3.100 / 60. 3.100 libavformat 60. 3.100 / 60. 3.100 libavdevice 60. 1.100 / 60. 1.100 libavfilter 9. 3.100 / 9. 3.100 libswscale 7. 1.100 / 7. 1.100 libswresample 4. 10.100 / 4. 10.100 libpostproc 57. 1.100 / 57. 1.100 [aac @ 0000029a0d3a9e00] This stream seems to incorrectly report its last channel as LFE[5], mapping to LFE[0] Input #0, matroska,webm, from 'Almost Human S01E01 Pilot.mkv': Metadata: encoder : libDivXMediaFormat 4.0.0.0578 Duration: 00:45:37.32, start: 0.000000, bitrate: 1687 kb/s Stream #0:0(eng): Video: hevc (Main), yuv420p(tv), 1920x1080 [SAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 1k tbn (default) Stream #0:1(un): Audio: aac (LC), 44100 Hz, 5.1, fltp (default) Output #0, mp4, to 'out.mp4': Metadata: encoder : Lavf60.3.100 Stream #0:0(eng): Video: hevc (Main) (hev1 / 0x31766568), yuv420p(tv), 1920x1080 [SAR 1:1 DAR 16:9], q=2-31, 23.98 fps, 23.98 tbr, 16k tbn (default) Stream #0:1(un): Audio: aac (LC) (mp4a / 0x6134706D), 44100 Hz, 5.1, fltp (default) Stream mapping: Stream #0:0 -> #0:0 (copy) Stream #0:1 -> #0:1 (copy) Press [q] to stop, [?] for help frame=65630 fps=33590 q=-1.0 Lsize= 562395kB time=00:45:37.23 bitrate=1683.1kbits/s speed=1.4e+03x video:496752kB audio:63385kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.403130% ffprobe out.mp4 ffprobe version 6.0-full_build-www.gyan.dev Copyright (c) 2007-2023 the FFmpeg developers built with gcc 12.2.0 (Rev10, Built by MSYS2 project) configuration: --enable-gpl --enable-version3 --enable-static --disable-w32threads --disable-autodetect --enable-fontconfig --enable-iconv --enable-gnutls --enable-libxml2 --enable-gmp --enable-bzlib --enable-lzma --enable-libsnappy --enable-zlib --enable-librist --enable-libsrt --enable-libssh --enable-libzmq --enable-avisynth --enable-libbluray --enable-libcaca --enable-sdl2 --enable-libaribb24 --enable-libdav1d --enable-libdavs2 --enable-libuavs3d --enable-libzvbi --enable-librav1e --enable-libsvtav1 --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs2 --enable-libxvid --enable-libaom --enable-libjxl --enable-libopenjpeg --enable-libvpx --enable-mediafoundation --enable-libass --enable-frei0r --enable-libfreetype --enable-libfribidi --enable-liblensfun --enable-libvidstab --enable-libvmaf --enable-libzimg --enable-amf --enable-cuda-llvm --enable-cuvid --enable-ffnvcodec --enable-nvdec --enable-nvenc --enable-d3d11va --enable-dxva2 --enable-libvpl --enable-libshaderc --enable-vulkan --enable-libplacebo --enable-opencl --enable-libcdio --enable-libgme --enable-libmodplug --enable-libopenmpt --enable-libopencore-amrwb --enable-libmp3lame --enable-libshine --enable-libtheora --enable-libtwolame --enable-libvo-amrwbenc --enable-libilbc --enable-libgsm --enable-libopencore-amrnb --enable-libopus --enable-libspeex --enable-libvorbis --enable-ladspa --enable-libbs2b --enable-libflite --enable-libmysofa --enable-librubberband --enable-libsoxr --enable-chromaprint libavutil 58. 2.100 / 58. 2.100 libavcodec 60. 3.100 / 60. 3.100 libavformat 60. 3.100 / 60. 3.100 libavdevice 60. 1.100 / 60. 1.100 libavfilter 9. 3.100 / 9. 3.100 libswscale 7. 1.100 / 7. 1.100 libswresample 4. 10.100 / 4. 10.100 libpostproc 57. 1.100 / 57. 1.100 [extract_extradata @ 00000183f8ed8140] No start code is found. out.mp4: Invalid data found when processing input ffmpeg-directstream-7b838ee2-f835-4d18-94b2-bccce879fceb_1.txt embyserver (1).txt
Luke 42245 Posted April 24, 2023 Posted April 24, 2023 So this is only an issue when running from the command line?
hawk223 9 Posted April 24, 2023 Author Posted April 24, 2023 No these fail the Emby conversion process. I was manually trying to figure out why. It's still waiting for a solution. There is something with the file encoding that FFmpeg cannot handle.
Neminem 1623 Posted April 24, 2023 Posted April 24, 2023 (edited) This seams to be you problem. [aac @ 0000029a0d3a9e00] This stream seems to incorrectly report its last channel as LFE[5], mapping to LFE[0]] Stream #0:1(un): Audio: aac (LC), 44100 Hz, 5.1, fltp (default) It stops at Stream #0:1 Stream #0:1 -> #0:1 (copy) Press [q] to stop, [?] for help frame=65630 fps=33590 q=-1.0 Lsize= 562395kB time=00:45:37.23 bitrate=1683.1kbits/s speed=1.4e+03x video:496752kB audio:63385kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.403130% You could try running the command again but with output *.mkv Edited April 24, 2023 by jaycedk
Luke 42245 Posted April 25, 2023 Posted April 25, 2023 Can you provide a copy of this video for testing? It sounds like a bad or messy file, but maybe we can figure out a way to handle it.
hawk223 9 Posted June 1, 2023 Author Posted June 1, 2023 What's the best place to upload it too? I've also noticed an annoying oversite to conversion. I wish there was more customizability available. I have some HEVC HDR10 bit files that my player can't play without transcoding. I was hoping that conversion would fix that but it does not switch to 8-bit.
Luke 42245 Posted June 1, 2023 Posted June 1, 2023 14 hours ago, hawk223 said: What's the best place to upload it too? I've also noticed an annoying oversite to conversion. I wish there was more customizability available. I have some HEVC HDR10 bit files that my player can't play without transcoding. I was hoping that conversion would fix that but it does not switch to 8-bit. HI, dropbox or google drive would be great. Thanks.
Luke 42245 Posted August 18, 2023 Posted August 18, 2023 @hawk223are you still seeing this with Emby Server 4.7.13?
