Chalklands 27 Posted April 9, 2023 Posted April 9, 2023 Emby for Kodi Version: 8.1.1 Emby server on NAS: 4.7.8.0 Kodi Nexus 20.2 Nvidia Shield TV Pro Big problems. This started yesterday (Not sure if Emby For Kodi ungraded itself to 8.1.1?) Whenever I start Kodi I get the Emby message 'Processing Updates'. This has been running for hours and when I try to play a movie or TV show, Kodi freezes. The only way to stop Kodi freezing is to do a Force Stop on the Shield. I can't uninstall the emby for Kodi add on as Kodi freezes when I try to do this. I only use Emby in Kodi for Documentaries and Music Concerts, not for any other media. Is there anyway of uninstalling the Emby app manually (e.g deleting some files in file manager)? Hope somebody can help as currently Kodi is not useable.
Luke 42238 Posted April 9, 2023 Posted April 9, 2023 Hi, please attach both the Emby server log and kodi log files from when this happened. Thanks.
Luke 42238 Posted April 9, 2023 Posted April 9, 2023 17 minutes ago, Chalklands said: How do I get an emby server log? How to Report a Problem
Chalklands 27 Posted April 9, 2023 Author Posted April 9, 2023 Cheers Luke! I'll have a look in the morning. 1
Solution quickmic 1709 Posted April 10, 2023 Solution Posted April 10, 2023 17 hours ago, Chalklands said: Cheers Luke! I'll have a look in the morning. You can also send me a kodi.log and I'll review it. If you have file access , you can simply delete "../addons/plugin.video.emby-next-gen". This removes the plugin.
Chalklands 27 Posted April 10, 2023 Author Posted April 10, 2023 Hi, Removed the plugin and reinstalled using the stable version. Fingers crossed, all seems OK now. Thanks for the help. 1
