ebr 16306 Posted October 21, 2014 Posted October 21, 2014 You didn't tell us what you did or what actually happened other than that error was generated in the log so not sure exactly how to proceed. Unrelated, I think but you do need to update the Intros plug-in.
bsddork 0 Posted October 22, 2014 Posted October 22, 2014 (edited) I am getting the same error. Server is starting, but getting errors during startup. Eventually an error window pops up with this message and the server quits. I am unable to connect to the webgui. Server Log -> http://paste2.org/Up1AgG7O Error log -> http://paste2.org/DVLC0L9O Edited October 22, 2014 by bsddork
bsddork 0 Posted October 22, 2014 Posted October 22, 2014 (edited) Update: I have server working now... kind of... There appeared to be a problem with data\library.db because when I was attempting to backup the mediabrowser data, a library.db-wal file was created and was locked by another process, even when mediabrowser-server is killed. Using the CLI for sqlite3> pragma integrity_check; I found that the database was corrupted. http://paste2.org/HsVN9EwI I believe this is the result of me deleting an entire show's folder containing multiple seasons of episodes while server was running. I renamed library.db and restarted server. So far it appears to be back to normal. Currently it is rescanning the folders and the log viewer has not reported any errors. Edited October 22, 2014 by bsddork
