RonB26 15 Posted April 7, 2023 Posted April 7, 2023 Hello @TeamB I've run into an issue with a season not showing, and throwing a Kodi Error. I'm currently running the latest beta release (1.11.14) Since I don't have any older beta versions, I tested with the stable version (1.10.34) and the Develop version on github. The problem is not there with those versions. Is there someplace I can download older betas to test? Here is a snippet of the error in the Kodi (Ver 20.1) log EmbyCon Error Log.txt
TeamB 2440 Posted April 7, 2023 Posted April 7, 2023 thanks for reporting, I know what is causing this, I will have an update up in a few hours 1
TeamB 2440 Posted April 7, 2023 Posted April 7, 2023 new version available 1.11.15, it should fix the error it may crash the first time you access the season but try again and see if it fixes itself, the first error should clean any out of date cached data. 1
RonB26 15 Posted April 8, 2023 Author Posted April 8, 2023 That was fast, thanks! Tested, and now the folder is showing up, But, something is still not right. When I try to play the episode, nothing happens. I attached the log. EmbyConError2.txt
Solution TeamB 2440 Posted April 8, 2023 Solution Posted April 8, 2023 new build to try to fix playback, ver 1.11.16 1
