Jam_Lai 1 Posted April 6, 2023 Posted April 6, 2023 Could it be able to use custom name instead of the default english audio and subtitle name? thank you very much
Happy2Play 9812 Posted April 6, 2023 Posted April 6, 2023 You sort of have that option if your tracks are named and you change from Friendly track name to preferred embedded title. App settings-Library, Advanced tab "Embedded track title display:" setting
Jam_Lai 1 Posted April 7, 2023 Author Posted April 7, 2023 dear happy2play, really thanks, i just changed and check, it's better but it still display english name + custom name, can I remove the english name as in chinese, we have seperate the yue, simplifed chinese, traditional chinese.... in HK, we are using Yue...but I found that even I changed to yue in language in mkvtoolnix..it still showed simplifed chinese..
visproduction 335 Posted April 11, 2023 Posted April 11, 2023 Two letter Chinese is zh https://en.wikipedia.org/wiki/ISO_639_macrolanguage Three letter Chinese is: Quote zho is the ISO 639-3 language code for Chinese. Its ISO 639-1 code is zh. There are sixteen individual language codes assigned, most of which are not actually languages but rather groups of Sinitic languages distinguished by isoglosses: cdo – Min Dong Chinese cjy – Jinyu Chinese cmn – Mandarin Chinese cnp – Northern Ping Chinese cpx – Pu-Xian Chinese csp – Southern Ping Chinese czh – Huizhou Chinese czo – Min Zhong Chinese gan – Gan Chinese hak – Hakka Chinese hsn – Xiang Chinese lzh – Literary Chinese mnp – Min Bei Chinese nan – Min Nan Chinese wuu – Wu Chinese yue – Yue Chinese I use MP4Box in Windows to change language info in each .mp4 file. This will update the listing in each media page. This script will change all .mp4 languages in a folder and all subfolders, so one click on the batch file could update thousands of videos. Changing undetermined to the language, I just name each file like this: und2zh.bat (und change to Chinese zh) I don't think mp4box will handle the three letter code, but you can try. It's nice having these .bat files that work. You just copy the one you want into any folder and click on it. for /R %%f in (*.mp4) do "C:\Program Files\GPAC\MP4Box.exe" -lang 2=zh "%%f" echo completed pause The most used change, for another example, would be changing und to English. und2en.bat for /R %%f in (*.mp4) do "C:\Program Files\GPAC\MP4Box.exe" -lang 2=en "%%f" echo completed pause Hope that helps.
Jam_Lai 1 Posted April 11, 2023 Author Posted April 11, 2023 Thank you for your reply, visproduction. What I mean is could it be able to show the Embedded title without the language code, as I can custom the name of the audio/subtitle.
luser 37 Posted July 29, 2024 Posted July 29, 2024 Did the "Embedded track title display" setting get removed? I don't see it in the Advanced tab.
Luke 42245 Posted July 29, 2024 Posted July 29, 2024 8 minutes ago, luser said: Did the "Embedded track title display" setting get removed? I don't see it in the Advanced tab. It's not necessary anymore because all Emby apps except for Android TV and Roku display both the embedded title and emby generated title together. For Android TV and Roku we have decided that if users need to change the display of these, then having settings directly in the app would be the better way to go.
luser 37 Posted July 30, 2024 Posted July 30, 2024 (edited) I've only ever seen the embedded title shown if there are multiple audio streams in the video file. And even then it's shown underneath the "generated" title in grey text. I use the web client. Edited July 30, 2024 by luser
rbjtech 5344 Posted July 31, 2024 Posted July 31, 2024 I don't see this - only the Embedded Title Track ? This is the standard web client... Single Audio Track shows the Embedded Track as well .. ? All generated from the MediaInfo Plugin .. I do NOT want to see the Emby generated values, as they will just muddy the screen and present less accurate info than my embedded titles. 3 1
