Flywheel617 0 Posted April 3, 2023 Posted April 3, 2023 In the last week or so the xml guide that i have been using quit uploading. There are two version of the guide, an XML guide, and a .gzip The reason I want to use the gzip guide is because it is a 7 day guide and not just a 2 day guide. The XML guide shows up fine in tv guide, but the gzip file will not work, and the link is working properly, I am able to download and extract the gzip file into an xml file and confirmed the XML file is valid.
Luke 42242 Posted April 3, 2023 Posted April 3, 2023 Hi there, this is supported. Please try again and then attach the emby server log: How to Report a Problem Thanks.
Flywheel617 0 Posted April 3, 2023 Author Posted April 3, 2023 Having same issue and updated my server to 4.8.0.27+ with no success. Confirmed the gzip is valid as well. (The gzip file used to work just fine)
