NoWorries1968 7 Posted April 2, 2023 Posted April 2, 2023 I'm running two different endpoints with EMBY as the server. One is an NVIDIA shield which works perfectly. The 2nd is a Marantz Pre/Pro with HEOS and DLNA/UPNP in-built and this is where the problem starts and how to reproduce it. 1) Select a playlist, folder, song inside a folder, etc. 2) Music begins to play 3) At the end of the song, Music Stops, forcing me to manually select another song. 4) If I try to advance the song to the next one, it stops playing and won't play, forcing me to select another individual song. Summary: I cannot get a series of songs to play. Solution example: I have experimented with other Media Servers (trial basis). The Media Servers that worked incorporated two features on the top of all lists: 1) "Play All" 2) "Shuffle All" I've been trying to figure this out for a while now and any help appreciated.
Luke 42237 Posted April 2, 2023 Posted April 2, 2023 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
NoWorries1968 7 Posted April 2, 2023 Author Posted April 2, 2023 As requested.... I supplied several logs. Thank you!!! embyserver-63815961189.txt hardware_detection-63815961304.txt embyserver-63815990400.txt
Luke 42237 Posted April 4, 2023 Posted April 4, 2023 Hi, we'll take a look at it. Thanks for reporting. 1
Luke 42237 Posted April 12, 2023 Posted April 12, 2023 @NoWorries1968 are you still running into this with the latest update to the Emby DLNA plugin that went out in recent days?
NoWorries1968 7 Posted April 24, 2023 Author Posted April 24, 2023 On 4/11/2023 at 8:09 PM, Luke said: @NoWorries1968 are you still running into this with the latest update to the Emby DLNA plugin that went out in recent days? Luke - apologies. I didn't see your response or the update that occurred. I had to remove music from Emby, but now that I've seen this I will add again and report back. 1
