jsc1205 51 Posted April 1, 2023 Posted April 1, 2023 I'm having an issue with Batman The Animated Series displaying in DVD order. I'm scraping the metadata info from TMDB and there is a DVD order under Episode Groups but for some reason when I switch the Display Order in Emby, it does nothing. Any idea why??
GrimReaper 4848 Posted April 1, 2023 Posted April 1, 2023 (edited) 3 minutes ago, jsc1205 said: Any idea why?? TMDB episode groups are not supported, only Aired. For TVDB, Aired/DVD/Absolute. If you want alternate order, you need to use TVDB. Edit: You can lend your support here: Edited April 1, 2023 by GrimReaper Link
jsc1205 51 Posted April 1, 2023 Author Posted April 1, 2023 Thanks for the quick response. Is this something that will be supported soon/future?
GrimReaper 4848 Posted April 1, 2023 Posted April 1, 2023 It likely will, some time in the future. When is a different matter. On 9/28/2020 at 5:32 PM, Luke said: The episode grouping feature is something we can look at supporting in future updates, yes.
Happy2Play 9800 Posted April 1, 2023 Posted April 1, 2023 Future yes as technically both TVDB and TMDB plugins have to be reworked to extend these options then the UI will have to be changed also as there will have to be a distintion between orders per provider ie TVDB or TMDB.
