alexpunga148 4 Posted April 1, 2023 Posted April 1, 2023 According to logs, scaling can be accelated, but it does not. Is there any reason for that? ffmpeg-transcode-6ac043b3-8f71-4993-af6a-eee8da6d5206_1.txt
ebr 16332 Posted April 1, 2023 Posted April 1, 2023 Hi. Do you have Emby Premiere? Hardware acceleration is a Premiere feature on most platforms. https://support.emby.media/support/solutions/articles/44001173099-emby-premiere-feature-matrix
alexpunga148 4 Posted April 1, 2023 Author Posted April 1, 2023 7 minutes ago, ebr said: Hi. Do you have Emby Premiere? Hardware acceleration is a Premiere feature on most platforms. https://support.emby.media/support/solutions/articles/44001173099-emby-premiere-feature-matrix Yes, I've got. As you can see, transcoding from h265 to h264 uses hardware acceleration, bu scaling doesn't. Logs say that hardware acceleration is supported
softworkz 5133 Posted April 2, 2023 Posted April 2, 2023 The reason here is the required color conversion from yuv420p10 to yuv420p, which can't be done in hw.
alexpunga148 4 Posted April 2, 2023 Author Posted April 2, 2023 20 minutes ago, softworkz said: The reason here is the required color conversion from yuv420p10 to yuv420p, which can't be done in hw. Makes sense. Is that required by shield's hardware encoder? I noticed that transcoding on every device requires color conversion
Solution softworkz 5133 Posted April 2, 2023 Solution Posted April 2, 2023 There is a spec for H.264 with 10bit color, but that is rarely supported. No hardware encoder or decoder I know supports it.
