Major_Minor 4 Posted March 29, 2023 Posted March 29, 2023 When you goto emby's main web page and click login, you are sent to this url where you can sign up or sign in. This url is not using HTTPS and further if you manually use HTTPS, the page returns blank. I looked at bottom of web pages for a link to report a site issue and I looked at all forum areas but there is no good place to post this. Seems a bit hard to believe I am the only one noticing it. I would appreciate anyone suggesting how I report this. http://app.emby.media/#!/startup/connectlogin.html
GrimReaper 4848 Posted March 29, 2023 Posted March 29, 2023 (edited) 7 minutes ago, Major_Minor said: Seems a bit hard to believe I am the only one noticing it. You're not, number of topics existing, example: Edited March 29, 2023 by GrimReaper Cross-posted 1
Luke 42186 Posted March 29, 2023 Posted March 29, 2023 11 minutes ago, Major_Minor said: When you goto emby's main web page and click login, you are sent to this url where you can sign up or sign in. This url is not using HTTPS and further if you manually use HTTPS, the page returns blank. I looked at bottom of web pages for a link to report a site issue and I looked at all forum areas but there is no good place to post this. Seems a bit hard to believe I am the only one noticing it. I would appreciate anyone suggesting how I report this. http://app.emby.media/#!/startup/connectlogin.html Hi, where exactly is the blank page? I can't reproduce that.
Major_Minor 4 Posted March 29, 2023 Author Posted March 29, 2023 It happened when I clicked skip. I received a page with the emby logo in top left and a back (left arrow) icon. The rest of the page was blank. I tried just now and I am getting a form which looks correct (sans https)
Major_Minor 4 Posted March 29, 2023 Author Posted March 29, 2023 I think yes via http. Not sure if I should be getting second login request. Im new to the emby community. I see 2 folders (icons). 1 - Manually Select Server 2 - Sign on to Emby Connect (WHY?) (Shouldnt i automatically be logged in already) Also I know that when trying to use IOS app, after entering good creds, I end up on the same login screen. I know the pwd is correct because if I put wrong pwd in I get an error. So i seem to be in a login loop. (Ill open a separate thread for this after I can use https login. IS THERE AN ETA FOR HTTPS fix)
Luke 42186 Posted March 29, 2023 Posted March 29, 2023 Quote 2 - Sign on to Emby Connect (WHY?) (Shouldnt i automatically be logged in already) Yea I suppose this would be nice, but the forum and the web app are built differently and therefore sharing that information is not so easy.
Luke 42186 Posted March 29, 2023 Posted March 29, 2023 Quote Also I know that when trying to use IOS app, after entering good creds, I end up on the same login screen. I know the pwd is correct because if I put wrong pwd in I get an error. Most likely you are confusing the differences between Emby Connect vs locally managed users on your Emby Server, and you're trying to use Emby Connect credentials on your local server sign in screen, or vica versa.
Luke 42186 Posted March 29, 2023 Posted March 29, 2023 Quote IS THERE AN ETA FOR HTTPS fix What fix do you mean? The blank screen?
