David Patt 21 Posted March 29, 2023 Posted March 29, 2023 (edited) Hello always stream over network cable so i dont have problem with bitrate etc but now i am only on wifi and my only display is tablet (samsung s7 +) it has usb c. My server us on windows minipc with external hdd. So i get idea to connect over usb but it will connect ? Or i rather get something like rj45 to usb convertor ? Thank you for suggestions. Edited March 29, 2023 by David Patt New info
GrimReaper 4897 Posted March 29, 2023 Posted March 29, 2023 1 minute ago, David Patt said: So i get idea to connect over usb but it will connect Connect to what?
David Patt 21 Posted March 29, 2023 Author Posted March 29, 2023 Sorry forget add .my emby swrver is on windows mini pc with external hdd
GrimReaper 4897 Posted March 29, 2023 Posted March 29, 2023 Still not getting complete picture: is there a router/modem/switch somewhere in there? Do you want to connect directly to the server machine (in which case you'd need crossover LAN cable) or extend your wired network (in which case you'd use straight LAN cable)? Either way, I reckon you'll be depending on your SoC modem as I seriously doubt your tablet has dedicated controller chip.
David Patt 21 Posted March 29, 2023 Author Posted March 29, 2023 Directly to server machine i want avoid shitty router i have from isp provider and right now i cant get any other but have acces to switch. But want avoid it also this will be temporery setup until i move.
pwhodges 2033 Posted March 29, 2023 Posted March 29, 2023 1 hour ago, GrimReaper said: (in which case you'd need crossover LAN cable) Lol - it's two decades since I had to use a cross-over network cable; I've not even seen one since then! Paul 1
GrimReaper 4897 Posted March 29, 2023 Posted March 29, 2023 Just now, pwhodges said: Lol - it's two decades since I had to use a cross-over network cable; I've not even seen one since then! Paul Ditto.
