MBSki 1115 Posted April 1, 2023 Posted April 1, 2023 2 minutes ago, VicMoore said: I will look into all of these issues today The latest plugin dll is attached below. The custom filter is not finished yet. I fixed lots of bugs. Vic Emby.Bulky.dll 332.5 kB · 0 downloads Thanks @VicMoore. Did you get a chance to look at the potential recursive search issue or looking at that today?
VicMoore 755 Posted April 1, 2023 Posted April 1, 2023 It's on my list for today - also try the new plugin - the custom filter is not finished but you can see the GUI Vic
MBSki 1115 Posted April 1, 2023 Posted April 1, 2023 6 minutes ago, VicMoore said: It's on my list for today - also try the new plugin - the custom filter is not finished but you can see the GUI Vic Awesome, thanks @VicMoore!
GrimReaper 4906 Posted April 1, 2023 Posted April 1, 2023 (edited) 21 minutes ago, VicMoore said: I will look into all of these issues today The latest plugin dll is attached below. The custom filter is not finished yet. I fixed lots of bugs. Vic Emby.Bulky.dll 332.5 kB · 0 downloads Vic, please attach any subsequent plugin updates in the first post (which you can edit now), preferably (but not mandatory) with version number update and/or changelog/release notes. Edit: If you encounter any issues doing so, you can PM me the dll and/or notes and I'll do it for you, but this practice of sticking updates in the middle of the thread should cease, as it creates confusion both for new users and followers. Edited April 1, 2023 by GrimReaper Append
VicMoore 755 Posted April 1, 2023 Posted April 1, 2023 @GrimReaperyou and @Cheesegeezerwill make a programmer out of me for sure. Thanks for the help. I will start doing it ASAP Vic 1
VicMoore 755 Posted April 1, 2023 Posted April 1, 2023 Attached is version 1.6 of the plugin - the custom editor is finished but only slightly tested. Vic Emby.Bulky.dll 1
GrimReaper 4906 Posted April 1, 2023 Posted April 1, 2023 We just spoke what should you do with plugin updates, didn't we? Which you did for 1.5 thereafter. Yet here's 1.6 again in the thread. 1
VicMoore 755 Posted April 1, 2023 Posted April 1, 2023 @GrimReaperI have been told that driving people crazy is one of my best skills. I am teachable, especially new tricks. I did update the first post as you recommended. I am not sure if I should stop posting the code in other posts. You were not clear on that point. vic 1
MBSki 1115 Posted April 1, 2023 Posted April 1, 2023 6 minutes ago, VicMoore said: what did I do? Vic LOL, just post the update in the first entry in the thread.
GrimReaper 4906 Posted April 1, 2023 Posted April 1, 2023 1 minute ago, VicMoore said: I did update the first post Way to go, just saw the update. Just now, VicMoore said: I am not sure if I should stop posting the code in other posts. No need to post them on multiple places, just post "Plugin updated" or something similar in the thread body will suffice.
VicMoore 755 Posted April 1, 2023 Posted April 1, 2023 I Promiss to do that from now on. Sorry @GrimReaper. Did I mention that I am a slow learner vic 1
Happy2Play 9814 Posted April 1, 2023 Posted April 1, 2023 Yep the conflict of not being in the catalog. These non-catalog plugins to a point need a lock plugin descriptive topic with the plugin and a separate troubleshooting/issues discussion.
VicMoore 755 Posted April 1, 2023 Posted April 1, 2023 I just attached plugin version 0.0.1.7 to the first post. I fixed the custom filter and several minor bugs. Everything should be working now. Vic
MBSki 1115 Posted April 2, 2023 Posted April 2, 2023 11 minutes ago, VicMoore said: I just attached plugin version 0.0.1.7 to the first post. I fixed the custom filter and several minor bugs. Everything should be working now. Thanks @VicMoore. I think the case sensitivity is gone, and recursive search seems better, but it only appears to search 1 level down, rather than all levels down.
VicMoore 755 Posted April 2, 2023 Posted April 2, 2023 @MBSkiglad that things are working better. When you use the Filter dialogue you are creating an Emby filter string that get appended to the URL I send to the server. The filtering work is all done by the Emby server. I only tell it what to search for. The custom filter is different. The plugin does all of the filtering work. So I can change it to do whatever I want. With it you can search on almost anything. Vic
MBSki 1115 Posted April 3, 2023 Posted April 3, 2023 On 4/1/2023 at 8:27 PM, VicMoore said: @MBSkiglad that things are working better. When you use the Filter dialogue you are creating an Emby filter string that get appended to the URL I send to the server. The filtering work is all done by the Emby server. I only tell it what to search for. The custom filter is different. The plugin does all of the filtering work. So I can change it to do whatever I want. With it you can search on almost anything. Thanks for the thought about the custom filter. I'm testing it now, but I don't really understand how I'm supposed to get it to work. So, what I want to do is search for the string (explicit) anywhere in my library. It could be in the title, filename, metadata, ... etc. There is no string search though, and there is no recursive = true option. Also, what do S, E, and C mean?
VicMoore 755 Posted April 4, 2023 Posted April 4, 2023 @MBSkiin the custom filter click the radio button "one or more true" then for the various item fields that you want to test, select "C" for contains, and put "explicit" in the text field. You can test your filter by clicking the test button. When you are ready to apply the filter to the items on the page where you clicked the "custom" button, you just need to click the apply button. Vic
VicMoore 755 Posted April 4, 2023 Posted April 4, 2023 @MBSkiwhen you are using the Emby filter (you clicked the filter button) the filter is applied to everything in the folder where you clicked the filter button. It's not applied just to the selected items. The filter doesn't care what's selected. The same is true for the custom filter. The selected items are just used for testing the filter. Another point is that when you use "recursive" you must specify what's to be included in the search and if you like you can also specify what's to be excluded. If you don't do this, Emby will not give you any search results. Vic
MBSki 1115 Posted April 4, 2023 Posted April 4, 2023 Ok, thanks @VicMoore. So here's my search. I clicked the music library and searched from there. I don't know why it's showing titles when I'm supposed to be searching everything in my music library. Also, as you can see by the results it's only grabbing albums with explicit in the Album title, but it's not grabbing all of them. And, it doesn't grab any songs so there doesn't appear to be any recursive search. It's just searching the albums. Search Parameters Results Explicit Album NOT found
VicMoore 755 Posted April 4, 2023 Posted April 4, 2023 Good morning @MBSkithe custom filter doesn't search recursively. It only applies the filter to the current folder. I use the Emby filter to create a folder with all the items in it that I want to search across. For example, for TV shows I would select the Series I am interested in and then filter on "Recursive" and include "Episodes". Then I would use the "Custom" filter to search across all of the "Episodes" in the folder. Your effort testing these filters is a big help to me. Thanks so much. Vic
MBSki 1115 Posted April 4, 2023 Posted April 4, 2023 12 minutes ago, VicMoore said: Good morning @MBSkithe custom filter doesn't search recursively. Ok, so how do we get the recursive search? At the moment, there's no way to search all the songs. Any idea why the album search didn't return all the items with "explicit"?
VicMoore 755 Posted April 4, 2023 Posted April 4, 2023 You do the recursive search before you do the custom search - let me try a few things and I will get back with you this afternoon Vic
MBSki 1115 Posted April 4, 2023 Posted April 4, 2023 12 minutes ago, VicMoore said: You do the recursive search before you do the custom search - let me try a few things and I will get back with you this afternoon Vic Hmmm, ya lost me.
