Kiniu 22 Posted December 31, 2025 Posted December 31, 2025 Hello Everyone. Change picture not working. At all any suggestions?
seanbuff 1357 Posted December 31, 2025 Posted December 31, 2025 Hi @KiniuI have moved your post to the Bulky topic, thanks.
caveman456 2 Posted January 1 Posted January 1 On 12/13/2023 at 8:31 AM, MatthieuM said: Thank you for this plugin. I am trying to bulk edit a set of videos for "3D format:" but I cannot locate this same metadata in the "Bulky" utility. Is it perhaps not supported ? Emby proposes the following options for the "3D Format" metadata: HSBS / HTAB / FSBS / FTAB / MVC Thank you. I too am trying to bulk edit a bunch of 3d titles. I'm trying to remove the 3D flag from 50+ videos and cannot find a way to edit this field with Bulky Edit.
Kiniu 22 Posted January 2 Posted January 2 Hey Guys, I gave a problem bulky because "change picture" button doesn't work. It hoovers but not react to click. Any suggestions?
the-dumb1 136 Posted January 4 Posted January 4 On 8/4/2025 at 1:31 PM, kbeck said: If anyone has the problem with Folders on and only seeing a hash symbol instead of files (#), I found a workaround. My Library has 1 main folder, with about a dozen sub-folders and then the movie folders under them. I created an empty folder in the root of the Library folder, added it to the Library and everything shows. I:\Animated Shorts (Library points to here) I:\Animated Shorts\Looney Tunes I:\Animated Shorts\Looney Tunes\Folder1 I:\Animated Shorts\Looney Tunes\Folder2... I:\Animated Shorts\Disney I:\Animated Shorts\Disney\Folder1 I:\Animated Shorts\Disney\Folder2 I:\xTest (Empty folder. Added to Library) This IS the solution. Just confirmed. THANK YOU! 1
Kiniu 22 Posted January 10 Posted January 10 This is not a solution to my problem. button still doesn’t work.
qh186111 0 Posted January 15 Posted January 15 On 3/29/2023 at 10:27 PM, Cheesegeezer said: You will be used to using the excellent web based Tool created to Bulk Edit any of your media Items This is now being converted to be run directly from the plugins Section inside Emby Server. An extremely powerful tool that saves time Current Status: Development Testing This is currently under development and is consistently evolving. For this reason the dll files will be posted at the bottom of this thread. Bug Reporting & Issues: Please report bugs and Issues in this thread. corrected the problem with critic rating Feature Requests: While we welcome feature requests, please note that bugs and issues take priority and that feature requests will be subject to review and may or may not make it to the plugin. CURRENT VERSION: DEV 1.0.13.43 INSTALLATION - NOTE: Default Target for installation is Emby-Server/programdata/Plugins - Please download the "dll" file below copy and paste dll to the plugins folder. restart your emby server as this is in Development you will need to clear your browser Cache after each install, or the new changes will not appear Enjoy DOWNLOAD CHANGELOG: Filtering has now been added Bugs and Issues Reporting link - NOW WORKING Added "Image Not Found" image removed backgrounds added a spinner fixed several bugs with save IsFavorite and Played finally fixed saving UserData (IsFavorite and Played) fixed a bug in the custom editor - the edit buttons are now displayed for the results of a search fixed bug in bulk save added managing collections added managing playlists when you edit metata data for an item you can cast the video to a tv or monitor on your network. I added this just for fun added the ability to edit live tv channel meta data changed Shift click to work more in the traditional was - you can select segments you can now change primary images added the ability to remove specific tags simplified the code retained image aspect ratios added show folders button removed "cast to tv" from the edit menu, added it to the Movie and TV screens fixed the "Image Not Fpund" for none video items removed "Folder" button from screens where it didnt belong fixed button problem with custom filter added better file not found images added "emby data" and "channels" fixed bugs enhanced Channels rewrote Explorer Bulky is a collaboration between @Cheesegeezerand @VicMoore Bulky is an Emby plugin and it is in the Emby plugin library. where can i download ?
GMEMedia 0 Posted January 18 Posted January 18 @qh186111You can find it in the Plugins Catalog, Metadata section.
