VicMoore 755 Posted November 6, 2023 Posted November 6, 2023 @axelslAttached below is the plugin with the change you suggested. Test it and let me know if it works as you planned. Vic Emby.Bulky.dll
Locutus64 125 Posted November 6, 2023 Posted November 6, 2023 2 hours ago, VicMoore said: Hello @Locutus64I was under the understanding that "articles" should not be included when creating search names. Vic Should be up to the end user, not the devs.
VicMoore 755 Posted November 7, 2023 Posted November 7, 2023 @axelslDo you approve the change you requested? Does it work as expected ? I need to know if its ready to be added to the main code. Vic
axelsl 19 Posted November 8, 2023 Posted November 8, 2023 @VicMoorethank you! Sorry it took me so long to reply I am out of town on business. Will try it right now and let you know
axelsl 19 Posted November 8, 2023 Posted November 8, 2023 Hi @VicMoore I tested it and I did not manage to get it to remove the channel number, even with checking the "Remove all channel numbers" check box. What can I provide to help you debug?
GrimReaper 4907 Posted November 8, 2023 Posted November 8, 2023 On 11/6/2023 at 10:14 AM, axelsl said: remove channel numbers from Live TV channels? Isn't that something already configurable in the UI for certain client apps, with the rest of them to follow?
VicMoore 755 Posted November 8, 2023 Posted November 8, 2023 @axelslI must have done something wrong. Let me check the code today. Vic
VicMoore 755 Posted November 8, 2023 Posted November 8, 2023 @GrimReaperI don't know if it is configurable. I will check. Vic
axelsl 19 Posted November 9, 2023 Posted November 9, 2023 21 hours ago, GrimReaper said: Isn't that something already configurable in the UI for certain client apps, with the rest of them to follow? Thanks for pointing me to that direction! I still would prefer to remove the channel numbers on channels I decide, which is what @VicMooreis implementing - I want to keep channel numbers for some for which it makes sense, but this is good in the meantime as I'd rather have no channel number that random numbers coming from my IPTV provider.
DirkA 0 Posted November 9, 2023 Posted November 9, 2023 Hi, I am using this app for quite some time now. Unfortunately after the last update the "apply" button when using the custom filter disappeared. Did I miss something? When I downgrade to one version before, it's working again, but the automatic update goes back to the latest version seconds after this... Any clues highly appreciated. Kind regards Dirk
VicMoore 755 Posted November 9, 2023 Posted November 9, 2023 @DirkAI think I fixed one problem and broke another. I will look into the missing "apply" button ASAP Vic 1
Locutus64 125 Posted November 10, 2023 Posted November 10, 2023 On 11/6/2023 at 5:45 AM, VicMoore said: Hello @Locutus64I was under the understanding that "articles" should not be included when creating search names. Vic Again this belongs upto the end-user to choose not the devs. There should be a built-in option but since there isn't I was wondering if it was something you could add to bulky? Thanks
VicMoore 755 Posted November 10, 2023 Posted November 10, 2023 @DirkAsorry for the slow response. I will try to fix the bug today. Vic
VicMoore 755 Posted November 10, 2023 Posted November 10, 2023 @Locutus64I agree that I need a Settings page. I am busy with other things at the moment and just don't have the bandwidth to do it. Things should slow down soon. Vic 1
DirkA 0 Posted November 10, 2023 Posted November 10, 2023 27 minutes ago, VicMoore said: @DirkAsorry for the slow response. I will try to fix the bug today. Vic Fine for me, take your time... Dirk
Locutus64 125 Posted November 10, 2023 Posted November 10, 2023 4 hours ago, VicMoore said: @Locutus64I agree that I need a Settings page. I am busy with other things at the moment and just don't have the bandwidth to do it. Things should slow down soon. Vic Sorry, my bad if I implied you. I meant Emby itself should have had this option all along.
VicMoore 755 Posted November 13, 2023 Posted November 13, 2023 @DirkAI just uploaded the plugin. It fixes the problem about the "Apply" button not showing. Let me know if it works now. Thanks for reporting the problem. Vic
DirkA 0 Posted November 13, 2023 Posted November 13, 2023 @VicMooreJust tested it, and it works just fine. Thank you for the fast resolution. Dirk
axelsl 19 Posted November 22, 2023 Posted November 22, 2023 Hi @VicMoore Maybe I did something wrong when I tested the first time but I retested and removing the channel numbers works great! Thank you!
VicMoore 755 Posted December 5, 2023 Posted December 5, 2023 I am in the process of rewriting the Bulky plugin. I will integrate the requested features during this task. It will take me awhile. Vic
Locutus64 125 Posted December 5, 2023 Posted December 5, 2023 3 hours ago, VicMoore said: I am in the process of rewriting the Bulky plugin. I will integrate the requested features during this task. It will take me awhile. Vic Does that include the articles?
VicMoore 755 Posted December 6, 2023 Posted December 6, 2023 Hello @Locutus64what does "articles" mean? The new design will allow editing everything within Emby Objects. Vic
Locutus64 125 Posted December 6, 2023 Posted December 6, 2023 1 hour ago, VicMoore said: Hello @Locutus64what does "articles" mean? The new design will allow editing everything within Emby Objects. Vic We had this conversation. That said articles The, And, La, etc....
Locutus64 125 Posted December 8, 2023 Posted December 8, 2023 COOl then when you get the new one up I'll have to give it a go. Thanks
