worthmo 12 Posted September 7, 2023 Posted September 7, 2023 I've used both localhost and IP to login to the dashboard and click on the Bulky plugin. Below is an example. http://192.168.0.5:8096/web/index.html#!/configurationpage?name=BulkyConfigurationPage
VicMoore 755 Posted September 7, 2023 Posted September 7, 2023 The failure is in the Emby ApiClient. I must be providing it incorrect information when I save the objects UserData. I have not been able to duplicate the problem. So I will put in checks to make sure that the ApiClient is getting valid data. I will do this late tomorrow. Vic
VicMoore 755 Posted September 8, 2023 Posted September 8, 2023 Good morning @worthmoAttached is an updated Plugin that traps the error message you are experiencing. I have tested it for hours and it has not failed. Give it a try. I hope it works for you also. If not, I will continue looking for a solution. Vic Emby.Bulky.dll 1
worthmo 12 Posted September 8, 2023 Posted September 8, 2023 I ran a quick test with the new dll and was able to successfully save a change. Thank you @VicMoorefor all your work on this issue! 1
gillmacca01 220 Posted September 8, 2023 Posted September 8, 2023 Confirmed. Just changed the tag for 25 Channels and it has successfully saved and updated the tags Many thanks
VicMoore 755 Posted September 8, 2023 Posted September 8, 2023 @gillmacca01and @worthmoyou deserve the thanks. You had to suffer through the problems. I just had to fix them. Without your reports and help the bugs would never get fixed. Vic
gillmacca01 220 Posted September 8, 2023 Posted September 8, 2023 Quick question. All my live tv tags start with country code in square brackets. Example [USA] GENERAL Is there a way to search by what is in the square brackets, including the brackets? Not a problem if I cant
VicMoore 755 Posted September 8, 2023 Posted September 8, 2023 Currently searching for a string inside a tag is not possible. Vic
gillmacca01 220 Posted September 9, 2023 Posted September 9, 2023 On 5/18/2023 at 1:18 PM, VicMoore said: Hello @fwemby67when you change channel metadata you need to lock it or Emby will often change it back to the original values. I know this comment is going back a bit, but just want to double check. Once I have changed the tag in Bulky (and before clicking save), do I need to lock the tag and then click save
VicMoore 755 Posted September 9, 2023 Posted September 9, 2023 Yes that was a while back. With channels I know some fields must be locked or the Emby system will revert them to their previous values. I know this was true for titles. It may also be true for tags. I would vote for locking the tags before saving. Vic
VicMoore 755 Posted September 9, 2023 Posted September 9, 2023 (edited) Everyone, I am working on the Channels tool within Bulky. I need feedback on what is good about the tool and what is bad. I am trying to create a friendly and easy way to create channels for VirtualTV. I tried to design the tool so the content for each channel can be easily viewed and modified. All media tagging is done by the tool automatically. Please give me comments and recommendations for improvements. Vic Edited September 9, 2023 by VicMoore
VicMoore 755 Posted September 10, 2023 Posted September 10, 2023 I just uploaded Bulky 1.0.8.7 It has bug corrections and many new features added to Channels. Vic
normaled 1 Posted September 14, 2023 Posted September 14, 2023 Hey there, new user here! Is there a way to bulk edit the "People" metadata? I'm not seeing that field as an editable option in bulky and couldn't figure out how to do it. 1
gillmacca01 220 Posted September 14, 2023 Posted September 14, 2023 Is there a way to bulk disable channels based on TAG? example: Have a tag called 'Delete', and only disable the channels with that tag
VicMoore 755 Posted September 14, 2023 Posted September 14, 2023 Hello @normaledIn the browser version of this tool I included editing people. I will put it back in the plugin version. I keep putting it off until someone asked for it. Give me a few days. Vic P.S. thanks for asking 1
VicMoore 755 Posted September 14, 2023 Posted September 14, 2023 Hello @gillmacca01You are asking for something very specialized. I will look into doing it. No promises. Vic 1
croaton 9 Posted September 19, 2023 Posted September 19, 2023 Hello, first big Thanks for this Editor, but if i mark more than one item and say lock all against changing, it locks only one item or nothing cheers
VicMoore 755 Posted September 19, 2023 Posted September 19, 2023 Hello @croatonNice to hear from you. Could you please give me more detail about your problem. As I see it you are bulk editing locks and it works for the first item but not the second. Vic
VicMoore 755 Posted September 19, 2023 Posted September 19, 2023 @gillmacca01and @normaledI have not forgotten your requests. I need a little more time. Vic 2
croaton 9 Posted September 19, 2023 Posted September 19, 2023 (edited) Hey Vic, As I said first Item will Locked all so nothing can be more changed, rest of the Library will be processed but no change, or have i missunderstood bulk edit, so i have to go into each item and say lock all? cheers Edited September 19, 2023 by croaton
VicMoore 755 Posted September 19, 2023 Posted September 19, 2023 @croatonNo you don't misunderstand. I just needed more detail. I will now try to duplicate the problem. Thanks for your help and for reporting this problem. Vic
VicMoore 755 Posted September 19, 2023 Posted September 19, 2023 @croatonI have duplicated the problem. The "lock all" in bulk edit is not being saved. I will fix it today. Thank you so much for reporting this. I will post the plugin late today. I have a Doctors appointment this morning. Vic
