Luke 42255 Posted October 31, 2024 Posted October 31, 2024 5 hours ago, AntonioP01 said: quando aggiungo nuovi contenuti ricevo questa risposta dal programma. 2024-10-31 11:26:55,908 - ERRORE - Impossibile recuperare i dettagli dell'articolo: URL non valido 'None/emby/Items': Nessuno schema fornito. Forse intendi https://None/emby/Items? Eccezione nel thread Thread-280 (process_payload): Traceback (ultima chiamata più recente): File "C:\Users\Antonio\AppData\Local\Programs\Python\Python313\Lib\threading.py", riga 1041, in _bootstrap_inner self .run() ~~~~~~~~^^ File "C:\Users\Antonio\AppData\Local\Programs\Python\Python313\Lib\threading.py", riga 992, in esecuzione self._target(* self._args, **self._kwargs) ~~~~~~~~~~^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ ^ ^^^^^^^ File "C:\Utenti\Antonio\Desktop\Nuova cartella (2)\emby-telegram-notifier-main\app.py", riga 145, in process_payload se non item_details["Elementi"][0].get("Panoramica"): ~~~~~~~~~ ~~~^^^^^^^^^ TypeError: l'oggetto 'NoneType' non è sottoscrivibile Re:
sereneden 0 Posted March 9, 2025 Posted March 9, 2025 On 12/5/2023 at 9:16 PM, jdazzle44 said: I created a python script that does exactly this. You can find it on github if you're interested. Example of a movie and series below Works perfect, thanks a lot!
muppet4k 10 Posted March 19, 2025 Posted March 19, 2025 On 3/9/2025 at 2:48 PM, sereneden said: Works perfect, thanks a lot! for me not working, I changed the port but still the same and the wrong network something with 172......
Luke 42255 Posted March 19, 2025 Posted March 19, 2025 3 hours ago, muppet4k said: for me not working, I changed the port but still the same and the wrong network something with 172...... Hi, there is a dedicated telegram plugin. Why not just use that?
muppet4k 10 Posted March 19, 2025 Posted March 19, 2025 5 minutes ago, Luke said: Hi, there is a dedicated telegram plugin. Why not just use that? where can I find the dedicated plugin?
Luke 42255 Posted March 19, 2025 Posted March 19, 2025 1 hour ago, muppet4k said: okay I found...but with no images I would suggest posting in the topic to ask the developer to add it.
