Achaos 0 Posted March 27, 2023 Posted March 27, 2023 Hola a todos, Tengo el siguiente problema, con la app de Emby en Fire TV y con la Chromcast HD, me pasa los mismo. Al poner a reproducir cualquier tipo de archivo, *.avi o *mkv al cabo de un tiempo, la imagen se acelera y el audio sigue normal. Dejo el log por si lo podéis revisar. Gracias de antemano. embyserver.txt
Luke 42245 Posted March 27, 2023 Posted March 27, 2023 HI, what version of the Emby app are you running?
ebr 16337 Posted March 27, 2023 Posted March 27, 2023 Hi. Are you positive this is happening on your MKV files and not just the AVI?
Achaos 0 Posted March 27, 2023 Author Posted March 27, 2023 Hola! La verdad, ahora me haces dudar. Diria que el capitulo que vi de la serie era mkv. Pero voy a intentar reproducir el problema y os digo.
Luke 42245 Posted March 27, 2023 Posted March 27, 2023 Hi. Can you try sideloading our standard android app on the same device and see how that compares? https://emby.media/emby-for-android.html Thanks.
Achaos 0 Posted March 28, 2023 Author Posted March 28, 2023 Hi, i have it installed on the Android app and it works fine, although sometimes on Chromecast it stays black and doesn't load, but it works directly on the TV through DLNA.
Luke 42245 Posted April 8, 2023 Posted April 8, 2023 On 3/28/2023 at 1:22 PM, Achaos said: Hi, i have it installed on the Android app and it works fine, although sometimes on Chromecast it stays black and doesn't load, but it works directly on the TV through DLNA. Hi, are you happy continuing to use that?
Achaos 0 Posted April 15, 2023 Author Posted April 15, 2023 Hi, I do not understand very well the question. Do you mean if I found the problem? And am I happy with using the Android app or the Chromecast app?
rodainas 191 Posted April 15, 2023 Posted April 15, 2023 45 minutes ago, Achaos said: Hi, I do not understand very well the question. Do you mean if I found the problem? And am I happy with using the Android app or the Chromecast app? Te está preguntando si estas contento utilizando la app de android como tal.
Achaos 0 Posted April 15, 2023 Author Posted April 15, 2023 Buenas, a pesar de estos detalles que os digo, en general está bien. Podría decir algunas cosas que me pasan, como desconexiones de la app con chromecast o cuando estoy viendo una peli o capítulo de una serie, y consulto otra peli o serie, aparece en la TV la sinopsi, pero de fondo se sigue ejecutando la serie o peli. Hay alguna cosa más pero no quería decirlas en este topic por no mezclar temas. No sé si me aconsejas subir la versión del servidor a una beta disponible? 4.8.0.21-Beta 4.8.0.28-Beta Ante todo, muchas gracias a todos.
Luke 42245 Posted April 16, 2023 Posted April 16, 2023 HI, I would try updating to the latest build and see how things compare. Thanks.
