Pejamas 58 Posted March 27, 2023 Posted March 27, 2023 Just wondering if anyone has got this to work at all? Im using a skin that has the images (AH2) and using the 21 nightlies that support DV playback. Both regualr version 20.1 and 21 have built in support to read the codecs of the files and display the HDR type yet with E4K Next gen its as if the HDR type cant be read. Everything else codec wise is picked up, such as the audio format and resolution etc.
quickmic 1709 Posted March 27, 2023 Posted March 27, 2023 4 hours ago, Pejamas said: Just wondering if anyone has got this to work at all? Im using a skin that has the images (AH2) and using the 21 nightlies that support DV playback. Both regualr version 20.1 and 21 have built in support to read the codecs of the files and display the HDR type yet with E4K Next gen its as if the HDR type cant be read. Everything else codec wise is picked up, such as the audio format and resolution etc. You can try this version but be careful. this is my current dev version, but it should include the tags (at least some of it).
