David Kugler 0 Posted March 26, 2023 Posted March 26, 2023 (edited) Hello, is anyone having issues with logging into emby with [redacted] on iOS. my login and password has not changed but keep getting invalid username or password. any help would be great. sincerely, David Kugler Edited March 26, 2023 by GrimReaper Server details removed
GrimReaper 4896 Posted March 26, 2023 Posted March 26, 2023 (edited) What's a "[redacted]? Edited March 26, 2023 by GrimReaper Server details removed
David Kugler 0 Posted March 26, 2023 Author Posted March 26, 2023 It’s my server that I have with emby. thanks, David Kugler
GrimReaper 4896 Posted March 26, 2023 Posted March 26, 2023 Is that remote or local connection? Are you logging in with your local user credentials or Emby Connect? Is iOS client app the only app you're facing issues with? If you connect locally with your Web app, are you able to log-in? Post server log.
David Kugler 0 Posted March 26, 2023 Author Posted March 26, 2023 local connection. Trying to log into emby connect when I try to log in with username and password I get incorrect username or password. it seems when I signed out of my apple iOS phone, I ran into the issues. I am still logged on my iPad iOS.
GrimReaper 4896 Posted March 26, 2023 Posted March 26, 2023 (edited) Based on your group, have you received an email relatively recently about changing your password maybe? In any case, you can try re-linking your local user with your Connect Account: Settings>Users>edit desired user>clear (Optional) Connect field, Save, re-enter your Connect account email, Save. Edit: Out of curiosity, why are you logging-in locally trough Connect? Edited March 26, 2023 by GrimReaper Append
David Kugler 0 Posted March 26, 2023 Author Posted March 26, 2023 When I download the emby app. it goes straight to emby connect. I live in Canada. it doesn’t allow me to go any further. that’s what my problem is. I have to log into emby connect but can’t log into my server.
GrimReaper 4896 Posted March 26, 2023 Posted March 26, 2023 I'm having trouble following you: do you have your own server set-up? Can you access it via Web app on your local network? Emby Connect has nothing to do with that, it is completely optional feature, mainly intended for remote access.
David Kugler 0 Posted March 26, 2023 Author Posted March 26, 2023 (edited) I do have a server set up for my [redacted] When I try setting it up manually, it comes up with a different user on my server. It is just frustrating, as my smart tv and iPad works just fine. Just can’t connect my iPhone to it. thanks, Edited March 26, 2023 by GrimReaper Server details removed
GrimReaper 4896 Posted March 26, 2023 Posted March 26, 2023 (edited) You:re constantly saying my server: 2 hours ago, David Kugler said: It’s my server 36 minutes ago, David Kugler said: can’t log into my server 24 minutes ago, David Kugler said: I do have a server set up for my [redacted] 24 minutes ago, David Kugler said: It comes up with a different user on my server. Yet when asked: 1 hour ago, GrimReaper said: If you connect locally with your Web app, are you able to log-in? 33 minutes ago, GrimReaper said: Can you access it via Web app on your local network? You provide no answer. If its yours, can you explain how did you set it up? Which platform runs it? What does server Dashboard show on the device you can connect (iPad)? Edited March 26, 2023 by GrimReaper Server details removed
David Kugler 0 Posted March 26, 2023 Author Posted March 26, 2023 (edited) [redacted] port 8096 Edited March 26, 2023 by GrimReaper Server details removed
GrimReaper 4896 Posted March 26, 2023 Posted March 26, 2023 So that's a server you've subscribed to? Someone gave you access?
GrimReaper 4896 Posted March 26, 2023 Posted March 26, 2023 Then you should investigate that with whoever owns the server as they are in no way related/affiliated with Emby nor questions like this have place on Emby forums. 1
