cncb 25 Posted March 24, 2023 Posted March 24, 2023 Is there any way to disable the DVR without losing all the settings? Basically I want to pause all tv recording for a while.
Luke 42242 Posted March 25, 2023 Posted March 25, 2023 Hi, there isn’t a pause. It’s not a bad idea to add but currently you’d have to delete your recording schedule.
cncb 25 Posted March 25, 2023 Author Posted March 25, 2023 Is this stored in the database or is there a separate file that I could rename?
Luke 42242 Posted March 29, 2023 Posted March 29, 2023 It's in the server data then live tv. You'll see some json files there. You can delete those and then restart the server.
Carlo 4561 Posted March 30, 2023 Posted March 30, 2023 On 3/25/2023 at 9:33 AM, cncb said: Is this stored in the database or is there a separate file that I could rename? Did you find the files Luke mentioned? On Windows they are located here: The example above is running under the Carlo account, but on your computer it will be a different username.
