GrimReaper 4848 Posted March 24, 2023 Posted March 24, 2023 5 minutes ago, Houfino said: Hi....I ask to add a function folder "genres" in emby..Animation doesn't belong to Japan....More like anime...I see it's missing... Anime vs animation..That's the difference Anime is typically referred to as animation that is produced from Japan Thank you *Moving to General/Windows as this is not a Feature Request* Genres will show whatever "genres" you have assigned to your media, even completely imaginary ones, either obtained from providers or assigned manually. If you want Anime to show as a genre - assign that genre to item(s) yourself. 1 1
Houfino 41 Posted March 24, 2023 Author Posted March 24, 2023 5 minutes ago, GrimReaper said: *Moving to General/Windows as this is not a Feature Request* Genres will show whatever "genres" you have assigned to your media, even completely imaginary ones, either obtained from providers or assigned manually. If you want Anime to show as a genre - assign that genre to item(s) yourself. Thank you...It works
