Tony B. 38 Posted March 23, 2023 Posted March 23, 2023 (edited) What is the variable for show file name (not full path) e.g. "D:\Recorded TV\The Show S01E12.mp4" The variable I'm looking for is one that would define JUST THIS: "The Show S01E12.mp4" Edited March 23, 2023 by Tony B.
rbjtech 5335 Posted March 23, 2023 Posted March 23, 2023 Which variable are you referring to - in the emby API ?
Luke 42186 Posted March 23, 2023 Posted March 23, 2023 Hi, there isn't one. How will your post processor application know what folder to look in if you only give it the file name?
Tony B. 38 Posted March 23, 2023 Author Posted March 23, 2023 Because it needs the file name, not the path. Working with databases with this post processing command. If there isn't a file name variable, then I'll just use MCEBuddy, it has one.
Luke 42186 Posted March 23, 2023 Posted March 23, 2023 24 minutes ago, Tony B. said: Because it needs the file name, not the path. Working with databases with this post processing command. Curious, what is it? What is your post processing application?
Tony B. 38 Posted March 23, 2023 Author Posted March 23, 2023 Plex "C:\Program Files (x86)\Plex\Plex Media Server\Plex Media Scanner.exe" --analyze-deeply --file "South Park S10E14 Stanley's Cup.ts" -x After the development team was very clear that Collections will 'never' go away, I started to use Plex for my library browsing and commercial scanning. No mandatory collections on a Plex. Emby still has a hands-down amazing live TV/DVR, so, I use it for that only
Luke 42186 Posted March 23, 2023 Posted March 23, 2023 Why do you think Collections are mandatory in Emby?
Tony B. 38 Posted March 23, 2023 Author Posted March 23, 2023 Because I can't disable them, can't remove the collections library in admin, and required to view on the fire stick (no way to disable them)
Neminem 1596 Posted March 23, 2023 Posted March 23, 2023 Have you tried to untick this library option. This will prevent collection auto creation, going forward.
Tony B. 38 Posted March 23, 2023 Author Posted March 23, 2023 Of course, but I'm still stuck looking at the library on the admin side and the fire stick (which has no option to hide). Don't bother man. It is over and done with.
GrimReaper 4848 Posted March 23, 2023 Posted March 23, 2023 31 minutes ago, Tony B. said: Of course, but I'm still stuck looking at the library on the admin side and the fire stick (which has no option to hide) Sure it does, you can hide it in Web App user Home Screen settings (and AndroidTV app will honor that), so you so don't have to look at it.
Luke 42186 Posted March 29, 2023 Posted March 29, 2023 On 3/23/2023 at 1:07 PM, Tony B. said: Of course, but I'm still stuck looking at the library on the admin side and the fire stick (which has no option to hide). Don't bother man. It is over and done with. @Tony B.why not just delete the existing collections that have been created? This can be done easily in bulk using the multi-select tool. Wouldn't you like to have a personal media server that doesn't send all of your info up to the cloud?
Tony B. 38 Posted March 29, 2023 Author Posted March 29, 2023 I still have to look at it on the fire stick and library setup, that's why
Luke 42186 Posted March 29, 2023 Posted March 29, 2023 2 minutes ago, Tony B. said: I still have to look at it on the fire stick and library setup, that's why Have you tried using the user profile option to hide the Collections library from your home screen? It will be gone from all Emby apps if you do that.
pwhodges 2023 Posted March 29, 2023 Posted March 29, 2023 (edited) Quote I still have to look at it on the fire stick and library setup, that's why You've been told how to stop seeing it on the FireStick, and how much time do you spend looking at your library setup? Paul Edited March 29, 2023 by pwhodges
Tony B. 38 Posted March 29, 2023 Author Posted March 29, 2023 There is not a "do not show collections" the Fire Stick like there is on the phone version. At least last I checked. The fact is, the collection takes up hard drive space, my time to explain it, and to reply to you. Someone I should have blocked long ago. It's over and done. Emby has it's power-areas, and that's something I continue to use, just not with their server admin for libraries and the user GUI. Your tone with me in your writing is unprofessional. I would hope that you don't make business decisions for Emby. I would appreciate it if you didn't directly reply to me anymore.
Luke 42186 Posted March 29, 2023 Posted March 29, 2023 4 minutes ago, Tony B. said: There is not a "do not show collections" the Fire Stick like there is on the phone version. At least last I checked. The fact is, the collection takes up hard drive space, my time to explain it, and to reply to you. Someone I should have blocked long ago. It's over and done. Emby has it's power-areas, and that's something I continue to use, just not with their server admin for libraries and the user GUI. Your tone with me in your writing is unprofessional. I would hope that you don't make business decisions for Emby. I would appreciate it if you didn't directly reply to me anymore. The user profile option can be done on web app or mobile app and it will apply to all devices, including fire tv.
GrimReaper 4848 Posted March 29, 2023 Posted March 29, 2023 6 minutes ago, Luke said: The user profile option can be done on web app or mobile app and it will apply to all devices, including fire tv. As OP was already informed: On 3/23/2023 at 1:40 PM, GrimReaper said: you can hide it in Web App user Home Screen settings (and AndroidTV app will honor that)
Happy2Play 9800 Posted March 29, 2023 Posted March 29, 2023 22 minutes ago, Tony B. said: he fact is, the collection takes up hard drive space, my time to explain it, and to reply to you. Someone I should have blocked long ago. If it is about space then you need to disable the library options, you need to delete all existing collection to clear item metadata creating then. As Emby will always read the item metadata.
Tony B. 38 Posted March 29, 2023 Author Posted March 29, 2023 It's not about space, it's about resource usage, visibility, and it's not something I want. Forcing me to deal with it is unacceptable so, I made my decision on that. On the app in the Android phone "home screen" configuration, is the only place visible to disable it. This does NOT show on my fire cube or stick. And I just looked at user configuration (again), not one check box for disable collections for users. This thread has gotten way off topic. Maybe someone should change the subject line to: "Come try to force me to use something I don't want to use" These responses have NOTHING to do with the variable question and the thread should be closed and/or moved to a private conversation. Either way this thread is a shit show.
pwhodges 2023 Posted March 29, 2023 Posted March 29, 2023 39 minutes ago, Tony B. said: On the app in the Android phone "home screen" configuration, is the only place visible to disable it. This does NOT show on my fire cube or stick. And I just looked at user configuration (again), not one check box for disable collections for users. Have you tried yet disabling it in the Web Client -> "user settings" -> "home screen" tab? which you've been told will be followed by the AndroidTV app on the FireStick? Paul
Tony B. 38 Posted March 30, 2023 Author Posted March 30, 2023 You don't read very well, Paul. Don't reply directly to my posts. 1.) I don't want collections visible anywhere on my server except for the button to totally disable them. 2.) No matter what, processor cycles are wasted on collections if one despises the idea of collections 3.) Installing or forceably adding features is not ethical. 4.) A single radio button for collections would have helped avoid conversations such as this. Of course I unchecked collections everywhere I could, they are still on my screen. Simple as that. 1
ebr 16307 Posted March 30, 2023 Posted March 30, 2023 7 hours ago, Tony B. said: Of course I unchecked collections everywhere I could, Hi. The image you showed above has them enabled:
Tony B. 38 Posted March 30, 2023 Author Posted March 30, 2023 That's cause I don't care or use Emby for viewing media, it might have been cleared of data, Emby does other things for me now. Hence, why I am seeing with these collections more often because the phone is used for admin. I didn't create them and I can't stop them from showing up. Kinda like a porn site would have with shit-tons of ads, you know you are going to be bombarded, but you use it anyway.
