Luke 42261 Posted April 21, 2023 Posted April 21, 2023 11 hours ago, Ronstang said: How long does it take to get an artist name with a slash in it added to the whitelist.....I requested a month ago, I'd kinf of like one of my favorite band's name to show correctly It gets added for the next release.
Ronstang 294 Posted April 21, 2023 Author Posted April 21, 2023 6 hours ago, Luke said: It gets added for the next release. Release of what? Stable Server or Beta? Because that seems like something you could put in the beta easy and then we wouldn't have to wait months.
Luke 42261 Posted April 22, 2023 Posted April 22, 2023 1 hour ago, Ronstang said: Release of what? Stable Server or Beta? Because that seems like something you could put in the beta easy and then we wouldn't have to wait months. Yes it goes into the betas.
Ronstang 294 Posted April 22, 2023 Author Posted April 22, 2023 1 minute ago, Luke said: Yes it goes into the betas. The betas have been updated since my request so why am I not seeing it? Just curious and asking, I'm not mad....LOL
Luke 42261 Posted April 22, 2023 Posted April 22, 2023 OK I missed 20/20. It will be in the next build. Thanks. 1
Ronstang 294 Posted April 22, 2023 Author Posted April 22, 2023 9 hours ago, Luke said: OK I missed 20/20. It will be in the next build. Thanks. Thanks Luke....only one of the best Power Pop bands of all time....that most don't know about. LOL 1
Battlestar 1 Posted December 29, 2024 Posted December 29, 2024 How do I add movie soundtracks to my Emby music library? Whenever I had a soundtrack folder Emby splits the songs based on the artist instead of leaving the sountrack album intact (Had the same problem with Plex)
user24 368 Posted December 29, 2024 Posted December 29, 2024 2 hours ago, Battlestar said: Whenever I had a soundtrack folder Emby splits the songs based on the artist instead of leaving the sountrack album intact Hi, you need to make "Album Artist" the same for all songs in an album. E.g. "Various Artists" or "Soundtrack". This is covered in Emby's basic documentation here: https://emby.media/support/articles/Music-Naming.html 1
MrAudio 22 Posted January 1, 2025 Posted January 1, 2025 (edited) On 12/29/2024 at 1:06 PM, Battlestar said: How do I add movie soundtracks to my Emby music library? Whenever I had a soundtrack folder Emby splits the songs based on the artist instead of leaving the sountrack album intact (Had the same problem with Plex) I recommend using Various Artists in the Album Artist field (for a soundtrack album or "jukebox" compilation) unless the same artist did all of the songs. On the individual songs, use a semi-colon to separate artist names. John Travolta; Olivia Newton-John Snoop Dogg; Dr. Dre; Eminem; 50 Cent This will allow Emby (and lots of other music players) to recognize that there are several individual artists who contributed to that track, and that track will show up under each of their names, because each name will be treated separately. Whereas "John Travolta & Olivia Newton-John" will be treated as a single artist, and the track won't appear under either person's individual profiles. I even do this for "featured artists" - their names get moved to the Artist field and separated with a semi-colon. If you put in songwriter tags, again, use semi-colons to separate the names, and they'll be treated as individual artists and will sort themselves properly. You may want to standardize on one name for an artist, so that they sort properly. For example: Snoop Doggy Dogg Snoop Dogg Snoop Lion Calvin Broadus Calvin Broadus Jr. Calvin Cordozar Broadus Jr. Calvin "Snoop Dogg" Broadus all refer to the same person. If you pick one variation and use it consistently across all tags when they appear, you'll get much better database results. Emby, as a rule, pulls its metadata from your ID3 tags when the songs are first imported, and making changes afterwards can be a bit of a hassle, so the better your tags are before you move the songs into Emby, the better your results will be. I'm a mobile DJ, so music management is a big deal to me, and I can probably answer any question you're likely to have. Edited January 1, 2025 by MrAudio 1
Luke 42261 Posted January 1, 2025 Posted January 1, 2025 @Battlestarplease let us know if this helps. Thanks !
Battlestar 1 Posted January 2, 2025 Posted January 2, 2025 1 hour ago, Luke said: @Battlestarplease let us know if this helps. Thanks ! Yes changing Album Artist worked great 1
