ndandrea 0 Posted March 22, 2023 Posted March 22, 2023 Utilisateur de Plex, désirant migrer... je m'interroge sur les fonctionnalité Free de Emby.... quelle sont les limitations de lecture en nombre et en device sur la version sans Abon ?? merci de votre réponse.
GrimReaper 4895 Posted March 22, 2023 Posted March 22, 2023 There is no device number limitation but certain client apps have some free features. For full list per-client/per-platform requirements/capabilities, see: https://support.emby.media/support/solutions/articles/44001173099-emby-premiere-feature-matrix
ndandrea 0 Posted March 22, 2023 Author Posted March 22, 2023 i don't understand anything about this matrix !!! i have my android device whith the app bought on Google play store and i haven' 1 min limitation !!!! can you explain me???
ndandrea 0 Posted March 22, 2023 Author Posted March 22, 2023 and can you explain me where can i have UNLOCK my android apps ?
GrimReaper 4895 Posted March 22, 2023 Posted March 22, 2023 1 minute ago, ndandrea said: i have my android device whith the app bought on Google play store and i haven' 1 min limitation !!!! If you have app unlocked on Google play, than you should have no 1-minute limit on playback. @ebr
ndandrea 0 Posted March 22, 2023 Author Posted March 22, 2023 ok i don't pay any app on google store !! i don't understand
GrimReaper 4895 Posted March 22, 2023 Posted March 22, 2023 Just now, ndandrea said: ok i don't pay any app on google store !! i don't understand I don't understand either. You said: 7 minutes ago, ndandrea said: i have my android device whith the app bought on Google play If you've bought it - you should have no limit and have full playback. If you haven't - you have 1-minute limit. What is unclear?
ndandrea 0 Posted March 22, 2023 Author Posted March 22, 2023 i have just click on Install, not Buy !
ndandrea 0 Posted March 22, 2023 Author Posted March 22, 2023 https://play.google.com/store/apps/details?id=com.mb.android
swenth 41 Posted March 23, 2023 Posted March 23, 2023 (edited) On 22/03/2023 at 17:41, ndandrea said: Utilisateur de Plex, désirant migrer... je m'interroge sur les fonctionnalité Free de Emby.... quelle sont les limitations de lecture en nombre et en device sur la version sans Abon ?? merci de votre réponse. Sur emby sans l'abonnement tu peux ecouter seulement 1 minute sur l'app android sauf si tu paye pour une lecture ilimité dans l'app comprend tu mieux? Ca ressemble a ca Edited March 23, 2023 by swenth
Luke 42239 Posted March 23, 2023 Posted March 23, 2023 HI, we work very hard on Emby and we thank you for your support.
ndandrea 0 Posted March 24, 2023 Author Posted March 24, 2023 10 hours ago, swenth said: Sur emby sans l'abonnement tu peux ecouter seulement 1 minute sur l'app android sauf si tu paye pour une lecture ilimité dans l'app comprend tu mieux? Ca ressemble a ca je n'ai pas cette option sur mon app ...
Luke 42239 Posted March 29, 2023 Posted March 29, 2023 On 3/24/2023 at 5:16 AM, ndandrea said: je n'ai pas cette option sur mon app ... Hi, what option exactly is missing?
